ECU fuse or fuses??
does anyone know how many fuses are fitted in the fuse box for the ECU on the 5-door J? am I right in thinking its fuse no.1 and fuse no.15?? anyone know why two fuses are referenced???
sheppy1 - Replies:
Rear Fuse Box
Have spoke about this with a few people on here before but just wanted to post some pictures of it now. This is the left hand side boot compartment which I believe is supposed to have the rear fuse box in it if I had one. Am I looking in the correct compartment for starters?
[ATTACH=CONFIG]368[/ATTACH]
[ATTACH=CONFIG]369[/ATTACH]
GDM123 - Replies:
Power for Dashcam and Mysterious Fuse
Evening,
Have seen the below post with regards to power for dashcam but i am looking to wire into the fuse box. This was relatively easy on my Corsa D i just tapped into the heated seats that the car did not have and i got power. With the Astra i have found that i either can only find constant lives or dead feeds. I am wanting to tap into a power source that is live when the car is on accessory but when i have tried tapping the 12v socket at the front it will not power anything unless it is
Rear fuse box Astra sri 2014
Hi new to the forum and the Astra
Just got this vehicle yesterday and can't find any fuse box in the boot looked behind the cover nothing
Any help please
seat heating control module Fuse
Anyone know what 30amp fuse it’s for the seat heating control module?
Info I got it from,
Battery positive voltage is supplied at all times to the seat heating control module through a 30 A fuse located in the underbonnet fuse block. This voltage is used by the module to supply power to the seat heating elements. Ground for the module is provided at G307.
leeso - Replies:
Rear Fuse Box
Hi, Does anyone know if the rear fuse box in an Astra J 2.0 S/S Elite 14 reg is coded to the car or could I just swap it for another one, thanks.
rear fuse box
hi what is the fuse number of the live wire that goes to the reversing lamp
Possible to install boot fuse board?
Hello,
I know this is probably a stupid idea and question but is it possible to install a rear boot fuse board?
If it is possible I want to install TPMS and an anti dazzling mirror, unless all this can be done without a rear fuse board?
I look forward to seeing the comments,
Thank you,
Callum. W.
steveh - Replies:
astra drl fuse or relays??
I'm completely stuck here with my DRLs.
My DRLs do not work nor do my side lights, so this is making my main dipped beam come on, i can not seem to find the fuse/fuses for these lights only a pair of relays which i thought DRLs did not need but hey oh.
so what is my next move,,, where should i be looking now? i'm not that great with electrics on a car but i would have thought this might have been an easyish fix.
i have nothing on the dash telling me of an error or light/lights not working
