fuses
Fuses
Hi guys,
Today my washers wouldn't work so checked the fuse in the engine bay and it had blown.
Tried a few places to get a new fuse but no joy, only tried walking distance tho lol.
So I thought, on my vectra the fuse box had some spares.
Looked at the book with the fuse diagrams and looked in the boot, I needed a small 10amp fuse.
Under location 7 was blank in the book but a red fuse in there.
I've taken it out and put in the washer space and it worked.
I want to know if the books are correct and the fuses are not trim specific etc....
No lights on the dash came up just wanted to make sure I hadn't stopped anything working.
think you have taken the seat heating fuse out
there is a full list of fuses here mate
http://www.vxoc.org.uk/forum/Thread-Fuses
there are fuses in the fuse boxes that are not listed
if they are not listed and are there they should be not used
you can get the small fuses from halfords
so it wont do any harm till you get there
the washer fuses can blow if the water in the pipes are frozen
this happens to save the motor from blowing up
it is best to use washer fluid that does not freeze
this time of year instead of water
Ye I thought that's why it had blown. I use a good mixture of screen wash and water but we been getting minus 3 and 4 in Wales recently.
I don't have heated seats in my astra but ye I think I should put one back in just incase!
no real need for the fuse if you dont have headed seats
have i look for a good screen wash that has a low freezing temp
I think controls the mirrors I know a lot of the fuses do more than 1 item so best to replace mate as soon as you can.
  ECU fuse or fuses?? JJ-Yorks 12 13,837 3:rd-Jul-2014, 20:12:08
Last Post: JJ-Yorks
