13:th-Aug-2020, 02:42:53
Does anybody know the size of the usb connection that plugs into the back of the radio headunit
Tags |
connector navi600 usb |
Navi600 usb connector
13:th-Aug-2020, 07:15:01
Lindy cable 31632 will go from sd port to navi
17:th-Aug-2020, 22:32:43
Thank you , do you know if I’m able to buy an adapter to take it up to standard usb connector , as I want to be able to use existing usb centre console connection with my aftermarket pioneer radio , so I don’t have to run extra cabling or fit a new flush mounted USB adapter
18:th-Aug-2020, 07:10:54
If you were to of asked that in your original question it would of been easier.
There is no adaptor that can fit the factory USB plug on the radio end. I'm assuming your keeping the SD port, USB & AUX port. If so you will want a Type A to Mini-B https://www.lindy.co.uk/cables-adapters-...ine-p11324 Astra-J 2.0 CDTI S/S
Driver door connector pinout | Mara_J | 5 | 4,550 |
14:th-Nov-2020, 09:53:25 Last Post: Rusty2009 |
Retrofitting Navi650 from Navi600 | dantheman | 0 | 3,449 |
20:th-Aug-2019, 14:16:16 Last Post: dantheman |
Airbag connector | BishopSRB | 5 | 4,312 |
26:th-Jan-2019, 22:37:33 Last Post: BishopSRB |
ECO button connector diagram (start/stop) | aurega | 1 | 8,211 |
4:th-Nov-2018, 15:06:37 Last Post: Rusty2009 |
cd400 vs navi600 | niteram | 7 | 6,463 |
27:th-Aug-2018, 09:02:10 Last Post: Rusty2009 |
Who read this thread? |
2 User(s) read this thread: |
James37518 (15:th-Jan-2024, 01:41:36), sdmodelar (3:rd-Apr-2024, 06:11:50) |
