How to add a Connector
This How to Covers How to Wire a Male and Female auto Connector
This is Really the Best way to join wires
or Add an Accessory that can be Unplugged Easily if Required
In this Case i am Adding Connectors
to my Load Resisters for my LED DRL,S
as this will make Taking the Headlights out much Easier
this will Help with Most Lighting Retro Fits etc.
You can Always Twist
Seat Connector Swap
Hi Guys
So it turns out the guy who sold me the elite seats was an idiot and cut the connectors off the bottom of the passenger seat!!! The garage are going to try and take the connectors from my old seat and splice them into the new seat...is that safe to do though and would the airbags work fine?
AUX Cable Connector
Does anyone have any photos of the AUX cable connector...I'm talking about the end that connects into wherever it goes behind the head unit.
loose green connector by gas pedal
Hi Guys,
Cleaning car today and in the drivers foot well to left of accelorator pedal I came across a loose green connector.
Could anyone advise if this should be un-connected or has come undone or if so where it should fix to?
I have a Astra J 2013 Sports Tourer 1.7 Diesel 130 bhp (A17DTS)
I have a pic link below if anyone could take the time to look ...  The bottom left of pic is the gas pedal and is of the right hand side of drivers foot well  (right hand drive) the cable is co
Anyone know what this connector is?
I've found this in my car today it's drivers side just behind the obd port.
Had a look on the forums and could only see someone on about the green DAB one.
Curiosity killed the car and all that.
Josh[Image: https://uploads.tapatalk-cdn.com/2018060...97e841.jpg]
ECO button connector diagram (start/stop)
Hello,
is here anyone how knows which cable is signal, plus and negativ for Start/stop system on this ECO button and connector?
Is there any existing diagram please?
Many thanks !
Airbag connector
Hi all
This is my first post, all i did so far was reading
My english is not so good but i'll do my  best.
I have a tiny problem on my astra, and i could use some help from you guys.
I tried to swap my steering wheel with leather one from insignia (found one at scrapyard)
All went well, until i tried to fit my airbag inside. Turns out it does not fit. So i go back where i bought the steering wheel and i buy the airbag too.
That was stupid act from my side (i gave 70 euros for t
Driver door connector pinout
Hi, i was searching for the Driver door connector pinout.
Can anyone help me?
Loudspeaker connector adapter
Can someone tell me will both of these two connectors work with front speakers for Opel Astra J from 2016. ?
ZRS-AG-2
ZRS-AG-21
In description for ZRS-AG-2 says it's good for all Opel models, and for ZRS-AG-21 says it's good for Opel Astra IV 2012->.
[color=#333333][size=small]Will ZRS-AG-2
Navi600 usb connector
Does anybody know the size of the usb connection that plugs into the back of the radio headunit
