snapped clips drl replacement
DRL Replacement - Snapped clips
Finally got round to replacing my DRL bulbs to some that are a bit more white. One issue.. i stupidly managed to snap the retaining clips on one side. The holder feels OK without them, and obviously the plastic cover is on the back. Am I likely to have any issues.. is this repairable at all??
On the plus side the Maruta (formerly MTEC) bulbs seem to fit OK and give off a nice white light. I have MTEC super white headlight bulbs which I've always found to be good. Plus they were a lot cheaper than PIAA bulbs.
Marc
If the bulbs holding and the cap is on you should be fine.
In terms of replacement you would need to get a light from the scrap yard.
  replacement key fob Qaranc 3 4,493 26:th-Apr-2021, 10:45:13
Last Post: rlievens
  P0135 after bcm replacement Saif.pro 11 8,699 30:th-Jan-2021, 10:20:19
Last Post: Saif.pro
  Caliper slide pins replacement? umognog 1 3,759 21:st-Aug-2020, 17:57:50
  Replacement Shark Fin Telsun 12 10,295 21:st-Jan-2019, 18:18:17
  Rear Light Replacement (Need Advice) A.ROD 2 7,298 17:th-Dec-2018, 19:17:48
Last Post: A.ROD
  Front brake pads replacement Phild82 3 6,736 16:th-Sep-2016, 05:15:24
Last Post: Phild82
  2.0 cdti battery replacement bannan 3 9,252 2:nd-Sep-2016, 15:20:46
Last Post: bannan
  Jacking clips on VX Line chrisb2511 3 6,150 27:th-Jul-2016, 22:48:31
  Clips/Screws in boot area. CRNeo 4 8,414 14:th-Sep-2015, 06:48:10
  Rear Seat Clips sheppy1 26 35,221 14:th-Feb-2015, 17:43:21
