caliper pins slide replacement?
Caliper slide pins replacement?
I could swear when I replaced my discs and pads two years ago, I saw a post on here about replacing the rubber sleeved slide pins with plain ones (by buying two packs). Cannot find it with any searching.
Anyway, I didn't do that back then (only had the one set) but I'll be damned the brake squeal has come back and I'm betting the caliper is sticking on that rubber boot two years later.
Looking to replace the slide pins for simply greased plain pins, that an ok/recommended thing to do and are the same pins used throughout the range? Looks like my new workshop is getting its first use!
I vaguely remember slider pins but only cleaning and re-greasing.
  replacement key fob Qaranc 3 4,742 26:th-Apr-2021, 10:45:13
Last Post: rlievens
  P0135 after bcm replacement Saif.pro 11 9,329 30:th-Jan-2021, 10:20:19
Last Post: Saif.pro
  DRL Replacement - Snapped clips Marc_81 1 3,744 3:rd-Aug-2020, 21:18:39
  Replacement Shark Fin Telsun 12 10,912 21:st-Jan-2019, 18:18:17
  Rear Light Replacement (Need Advice) A.ROD 2 7,514 17:th-Dec-2018, 19:17:48
Last Post: A.ROD
  Front brake pads replacement Phild82 3 6,960 16:th-Sep-2016, 05:15:24
Last Post: Phild82
  2.0 cdti battery replacement bannan 3 9,573 2:nd-Sep-2016, 15:20:46
Last Post: bannan
  Door Pins eddier1558 9 15,626 5:th-Jun-2016, 17:30:43
Last Post: J1ODYA
  Brake caliper painting pricee 12 11,850 2:nd-Apr-2016, 14:17:00
  brake caliper stickers tucpal 2 6,453 25:th-Oct-2015, 21:18:33
obsidian (2:nd-Aug-2025, 10:38:10)
