Best caliper paint?
I want to paint my calipers red, I don't want spray I want to brush it on, anyone got any recommendations?
tucpal - Replies:
brake caliper stickers
Nemo - Replies:
How-to Brake Caliper Colour Change
pricee - Replies:
Brake caliper painting
Hi GUYS,
Can anybody recommend a company in south Manchester/Cheshire area to paint my brake calliper's ?
cheer's in advance
Caliper Info
Hi guys,
I've got a 2011 Astra 1.6 SRi and need to replace a caliper.
Seen one from a 2013 1.4SRi, are they the same?
Front Caliper issues?? - Help please
Hey guys.
I had by car jacked up in the air with both calipers showing the pistons. When I pressed brakes only the passengers side piston would come out. When I original took calipers off the both retracted fine it's just that it won't come out??
The passenger side brake disc looks worse then the drivers as it is all rusty and not shiney but drivers side looks shiny. as hence why I thought something was wrong.
Anyone have any ideas to issues?
Thanks any help welcome.
Sent from my SM-G90
umognog - Replies:
Caliper slide pins replacement?
I could swear when I replaced my discs and pads two years ago, I saw a post on here about replacing the rubber sleeved slide pins with plain ones (by buying two packs). Cannot find it with any searching.
Anyway, I didn't do that back then (only had the one set) but I'll be damned the brake squeal has come back and I'm betting the caliper is sticking on that rubber boot two years later.
Looking to replace the slide pins for simply greased plain pins, that an ok/recommended thing to do and are t
