cluster instrument
Instrument cluster
Hello everyone,
I have an Opel Astra J 2.0 cdti automatic and since I bought it (2 years ago) I’m having an issue with the instrument cluster.
Actually it doesn’t show all the menus and never shows me messages when there’s a problem with the car, I tried to reprogram with op-com but I can’t access to it (I don’t know why) and I took it to Opel France and they told me you need to change the instrument cluster without any explanation.
So I decide to change it and I bought a used instrument cluster with almost the same number of kilometres and the same part number (13336484) and it works great and I reprogrammed it using I’m-com and now it shows all the menus I wanted to see.
But the issue is that it doesn’t show the mileage, it shows this ( - - - - - - ) instead of the mileage.
Om-com is showing me there’s a problem with the immobilizer identifier.
I searched so much to find a solution but I couldn’t find anything.
The pic with the yellow screws is the used instrument cluster I bought and the other one is the original.
So could you please help me ?
Your IPC needs programming to your car. I'm pretty sure you can't do that with opcom. It needs your vin programming into the IPC.
This is quite a specialist field for reprogramming clusters, have a word with @rusty . You'll probably find you'll have to ship it over to be sorted as a lot of people do.
Ok thank you for your advice guys. I will contact him. I hope it’s gonna work.
Yes the need de-programming from the original car and then reprogramming to your car with an MDI and SPS.
There could be an issue in that you've now played with op-com them it may have overwritten the original cars vin.
This can be checked real easy with op-com.
Either way it's possible but if the VIN has been wiped out it'll mean opening up the unit.
I checked the vin number on Op-com and each IPC shows me it own vin number so I think there’s no problem with that.
Is it possible that I send you my IPC so you solve the problem please ?
I live in France
Yes of course I see I have a PM from you which I will reply to in a minute.
  Digital cluster fit Jjmorris90 1 876 30:th-Apr-2023, 20:04:43
Last Post: milozic
  Instrument Cluster Cover sheppy1 13 7,773 10:th-May-2016, 21:10:33
  instrument cluster texaspete1973 6 5,081 15:th-Feb-2015, 20:56:07
dawid926 (24:th-May-2023, 13:21:12)
