clutch j depressed 2013 astra 4 noise 1 when
Noise when clutch 1/4 depressed 2013 Astra J
2013 Astra J SRI 1.7 diesel 130BHP   80K on clock
Engine noise when clutch 1/4 pressed & 1/4 released.
If car in neutral & clutch pressed 1/4 way down the noise is loudest,
Could it be DMF & if so what the cost approx of fitting?
Car running fine otherwise
Chirping noise Zaf312 1 37 Today, 07:34:19
  High pitched noise (Astra OPC J) maximame 0 4,519 24:th-Mar-2021, 08:34:13
Last Post: maximame
  Gear Knob issue (Automatic 2014 Astra GTC) DC23 1 5,335 22:nd-Feb-2021, 08:08:37
  Astra J. Can a tyre valve be replaced without replacing the TPMS? benawhile 2 3,869 5:th-Aug-2020, 12:33:14
Last Post: benawhile
  Astra GTC auto gear knob replacement Jayrich872001 12 20,572 22:nd-Jul-2020, 12:21:46
Last Post: DC23
  Astra J SRI 13 Plate - Radiator Fan Gavin1506 2 3,867 11:th-Jul-2020, 22:08:04
Last Post: Gavin1506
  Astra J 1.6 CDTi increased fuel consumption _Mita 2 5,497 1:st-Mar-2020, 22:27:38
Last Post: _Mita
  Electrik brake noise!! blacknik 1 4,814 24:th-Feb-2020, 08:57:02
  Astra ST 1,6 CDTi, error code P0181 claymansvk 1 2,862 20:th-Feb-2020, 19:32:31
  shock absorber noises astra j blacknik 1 4,791 10:th-Feb-2020, 08:34:15
