steering retrofitted heated successfully wheel?
successfully retrofitted heated steering wheel?
Hi, Does anyone retrofitted heated steering wheel?
I need to change the vinil steering wheel in favor of a leather one on my Astra j.
Since i will buy one i thought that i can buy the heated wheel.
I allready sorced the heather control with heated wheel button
As far as my logic goes i will need the folowing parts
1. Wheel itself
2. heather control
3. the airbag squib with
What else will i need to source? Is there a different loom from the squib to some other control module?
As soon as i get all the parts i will start a how to
Thanks in advance
It's been done before, just the parts you listed the wiring should be there already at the back side of the squib.
Thank you Rusty!
Will source aeverything and convert it.
Last question - is there a programming with Tech2 for this option to work?
I did it on mine, if I remember well you will need extra power supply for airbag squib.
Thanks Roksab!
Can you chim with some wiring diagram or pinout so i can check where to add the power suply
Thank you
Hello,
Can someone confirm 100% this is plug%play or i should change/add some control module or wires?
Is there any programing?
I just want to be sure before i spend my money on wheel and squib
Thank you
No programming is required.
Thanks Rusty!
And what about the additional power suply that Rosab mentioned?
How can i find to which pin of the squib plug to add +
Thank you
  Insignia vx flat steering wheel Anthonwr 1 2,737 25:th-Aug-2021, 11:41:29
Last Post: Vx-Mad-G
  Steering wheel remote control retrofit EricMod 32 22,558 10:th-Jul-2021, 12:37:38
Last Post: carolef1984
  Adding speed limiter from steering wheel? husky 4 7,207 17:th-May-2020, 17:25:37
Last Post: z8083
  Scale drawing or vector drawing of the 20inch VXR wheel. JohnL 18 14,449 7:th-May-2014, 16:07:28
  Heated washer jets Rusty2009 8 8,391 13:th-Apr-2014, 21:15:33
9 User(s) read this thread:
no_name (9:th-May-2024, 16:19:53), KKEVANSKK (10:th-Jun-2023, 13:48:56), Cozzer1990 (16:th-May-2024, 19:43:57), Phild500 (22:nd-Oct-2023, 12:28:24), Farkask14 (25:th-May-2023, 17:24:38), greg848484 (11:th-Jun-2023, 16:17:35), Jnny (4:th-May-2024, 11:59:05), ziTneY (16:th-Oct-2023, 21:11:36), Emil_Alexandru_Barb (23:rd-Feb-2024, 15:01:12)
