  • 1 Vote(s) - 1 Average
steering adding wheel? speed from limiter
Adding speed limiter from steering wheel?
Hello,
It is possible to add speed limiter to 2011 Astra?
My car have cruise control and i will replace the wheel for a heated one which happens to have also button for speed limiter.
What's involved in adding this option?
Thank you all
Not sure it can be done, I applied for a vci and they rejected it
Best bet is swapping the buttons over, I've tried a few VCI requests with no luck and even tried a work around but still no luck.
Thank you guys!
Sad story with these VCI codes vor everything...
No vci need just change cruise control from automatic electronic k33 to automatic adaptive k38 if available on sps configuration on ipc .
  Insignia vx flat steering wheel Anthonwr 1 4,807 25:th-Aug-2021, 11:41:29
Last Post: Vx-Mad-G
  Steering wheel remote control retrofit EricMod 32 38,310 10:th-Jul-2021, 12:37:38
Last Post: carolef1984
  Speed camera POIs Issue fezza37 2 5,349 26:th-Feb-2019, 22:25:04
Last Post: desmo
  successfully retrofitted heated steering wheel? husky 7 18,799 8:th-Sep-2018, 20:11:26
Last Post: husky
  Speed Limiter Lewis6317 10 19,040 17:th-Apr-2016, 19:41:52
Last Post: cosmo black
  Scale drawing or vector drawing of the 20inch VXR wheel. JohnL 18 27,002 7:th-May-2014, 16:07:28
