Speed Limiter
So does anyone know if it possible to have this added to an Astra J 2010 mk6 CDTi ECOFLEX 1.3?
I currently have cruise control, so apart from getting a new button would anything else need to be done?
Lost all speed and message pops up "Reduced power"
So my engines lost all it's power my engine management light pops on and also another message pops up saying car service soon
Getting pretty worried as I have a feeling it could be a something serious
I've got a friend doing a diagnostic tomorrow
Has anybody else in counted this or anything similar ?
M32/M20 6 speed gear box crap?
Just read that the gear box in my car ain't up to much. Is it true? It's fitted in all these engines
Astra: VXR / SRi Turbo 1.6, 2.0 / 1.9 CDTi
Corsa: VXR / SRi Turbo / 1.3CDTi / 1.7 CDTi
Meriva: VXR
Vectra: 1.9 CDTi / 2.2
Astra (M20): 1.3 / 1.7 CDTi
Speed Limiter
 Sorry for the many posts i have alot of different things i want to retrofit.
Does anyone know if there is any additional cabling for the speed limiter. I have bought a steering wheel with the speed limiter button on however my car doesnt have it. So rather than swapping the controls over i am think it could be retrofitted / actived with tis2web?
Alex
P0480-00 fan low speed don't work
I have DTC P0480-00 and low speed engine fan don't work.
Fuses 42 and 48 are OK
Relay KR20C is OK
I need electrical diagram for engine fan for more test.
Engine A20DTH with AC
Please, help me.
Information display speed doen't save
When i select menu 7 for displaying the speed, it will not be saved when i turn off the igision for about 10 minutes, and i have to select it again when i start the car.
Is there any way to save this setting?
ASTRA J Increase speed
Hi everyone I got astra J 2012 1.4 petrol n/a engine 100BHP, i've done my research on pedal box and will definetly purchase it soon as it does make a difference, i was wondering is it worth ecu remapping with only 10% gain bhp whilst at the same time using pedal box? Does anyone have same car is there any mods you done to make faster? My only problem is after 50mph it just goes up slowly not enough to overtake safely.
CD400, in meriva B, mid-speed can-bus off, wont allow can learn
Wondering if anyones had this before?
2011 meriva B (1.3 cdti) CD400 with GID,
always been getting the following code on the radio: U0074
[attachment=978]
The other 2 codes are for the IPC, as im still messing with it...
but i was getting that U0074 code when i only had an op-com for diagnosis, so it's not the clone tech2 giving a fake code, and i was getting it before i ever touched anything electrical in the car.
The Tech2 gives an option to do a can bus re-learn on most module
Adding speed limiter from steering wheel?
Hello,
It is possible to add speed limiter to 2011 Astra?
My car have cruise control and i will replace the wheel for a heated one which happens to have also button for speed limiter.
What's involved in adding this option?
Thank you all
Speed camera POIs Issue
I have recently done the Navi 600 to 900 hack, i have also updated my SD Card from 600 to 900 and have the red /blue theme and 3D maps all working great. and look great
the problem i have is the the Speed cameras are not showing correctly, i'm not getting the pop up warning, (i have enabled them and set it warn early)
[color=#ffcc33]Most importantly on the map it will show a 40 MPH icon when its actually 30 MPH,
