electrics towbar fitting
Towbar fitting/electrics
Has anyone ever diy fitted a towbar to there J. I need one for my sports tourer to pull my trailer. Just looking into it I want a removable Swan neck but there's two types of electrics dedicated and universal. Im just wondering if I buy dedicated does it just plug into the car. Does anything need activating in the ecu after fitting. I'm not worried about the spannering just don't wanna be chopping wires in my nice shiny astra
Sent from my E6553 using Tapatalk
There is a thread giving all info on universal and factory wiring.
i have had a read through the other thread rusty but my towbar wiring kit seems a bit different to the one in there
https://www.westfalia-automotive.com/fil...01-009.pdf
that is the instructions that come with the tow bar seems i have to tap into the brake light at the rear above the fuse board
tap into what they call a charging cable but i assume this is switched ignition live at the front fuse box and something behind the radio which i assume is to do with the parking sensors
and the put a couple of fuses under the bonnet
does this sound about right
just gotta find out what the colours are in the car now
I'll have a look later for you
  Double Din Fitting??? doug143 23 22,593 20:th-Jul-2020, 13:43:34
Last Post: stuartbigboy5454
  Will fitting downpipe pass MOT? MCG1983 1 5,296 4:th-Nov-2019, 10:43:45
Last Post: andyp
  Dab fitting Astra_sri 4 6,009 23:rd-Jul-2018, 07:56:04
  Fitting VXR seats newredgtc 17 18,991 25:th-Oct-2016, 17:34:24
Last Post: evo
  Fitting visible exhaust tip Jj0063 33 33,859 23:rd-Aug-2016, 09:42:13
Last Post: Rymaan82
  Fitting VXR bumpers? Morgan 4 8,423 15:th-Oct-2015, 09:59:43
Last Post: Morgan
