dab fitting
Dab fitting
Hi all so I have fitted the module and the bracket also fitted the aerial bit on the tailgate zr part.
Now I need to know what length wire and type of wire I need to for to the zr part.
And am I right in thinking there should be a double plug under the headlining for the fm and dab?
Many thanks
You will need Farka cable 5m.
No there isn't it's behind the panel by the bonnet release.
Ah ok so does that plug into the module then?
Ah ok thanks for that so one end plugs into the zr aerial where will the other end plug into as I’ve plugged in the green wire into the dab module.
Thanks again
Behind the kick panel by the bonnet release. Although TBH I'd just run from the ZR to DAB.
https://www.ebay.co.uk/itm/6m-Antenna-Ex...m570.l1313
  Double Din Fitting??? doug143 23 22,624 20:th-Jul-2020, 13:43:34
Last Post: stuartbigboy5454
  Will fitting downpipe pass MOT? MCG1983 1 5,310 4:th-Nov-2019, 10:43:45
Last Post: andyp
  Towbar fitting/electrics bunje 3 6,673 21:st-Dec-2016, 12:47:44
  Fitting VXR seats newredgtc 17 19,017 25:th-Oct-2016, 17:34:24
Last Post: evo
  Fitting visible exhaust tip Jj0063 33 33,885 23:rd-Aug-2016, 09:42:13
Last Post: Rymaan82
  Fitting VXR bumpers? Morgan 4 8,431 15:th-Oct-2015, 09:59:43
Last Post: Morgan
