an astra insignia hubs on
Insignia hubs on an astra
Not sure if its possible, but would the insignia's hub bearing + break disks fit on the astra's hub & driveshafts, and would I also need the caliper's of the insignia as well?
http://www.ebay.co.uk/itm/381178682477 does look like its the same 3 bolt fitment onto the hub.
I ask as alloys I am after are in 5x120, but with PCD adapters would stick too far out the arch.
2012 Astra J 2.0 cdti sri
That will be alot of work sure the rear hubs may well be a problem as the rear axle is totally different to the astra j and gtc I would say hub adapter will be better
Thought so :( shame Astra has strange PCD
Got a similar issue with my K the wheels I really want are 5x115 and the K is 5x105.
Surprised the K isn't 5x115 like the J
Why must Vauxhall be so inconsistent
Tell me about it I've not found a set of 5x105 alloys that really stand out
  Astra J GTC IPC pinout.. pistnbroke 0 3,324 10:th-Apr-2021, 08:08:43
Last Post: pistnbroke
  How to remove sun visor Astra J GTC. MCG1983 2 5,486 21:st-Sep-2020, 10:52:43
Last Post: MCG1983
  Astra J wing mirror mreledil 2 5,168 10:th-Apr-2020, 09:50:17
Last Post: andyp
  Astra j cd400 upgrade to cd500 [emoji2] Astragalcreb 4 8,111 16:th-Mar-2020, 22:41:28
  Astra MK6/J can bus log/dump file astra.cluster 0 7,236 3:rd-Oct-2019, 10:19:03
Last Post: astra.cluster
  Astra J vin help pls :( Cossie 3 9,804 4:th-May-2019, 10:21:37
  Astra J GTC 2.0 CDTi suspension entlio 3 10,590 30:th-May-2018, 08:32:57
Last Post: rlievens
  What are the specs for the wheel studs on a 2010 Insignia Sports Tourer? i.rosca 0 11,271 10:th-May-2018, 06:36:09
Last Post: i.rosca
  Astra J roof bars Gavinj87 0 7,464 13:th-Apr-2018, 20:21:51
Last Post: Gavinj87
  Astra j headlight repair kit workshop manual Cameron UK 4 12,951 18:th-Dec-2017, 19:41:33
