bore wheel alloy centre
Alloy wheel centre bore
Hi, I am trying to find out the correct centre bore for the alloy wheels I have and the alloy wheels I have been looking at. The alloys on our car are 70.2mm according to Wheel-Size.com, and the alloys from a 2015 Zafira are 70.3 according to the same source. Does this sound about right, and if so I take it that spigot rings would not be required as the difference is so small.
I have tried to look around but I keep on seeing different sizes, ranging from 70.1 to 70.3 for the 2.0cdti Astra, so I assume that maybe the 70.1 refers to the actual car hub? From the same search I can only find one pcd size for the 2015 Zafira, which is 5x115, does that sound correct also?
This will help you with the J centre bore but as for the zaffy I don't know
https://www.vxoc.org.uk/forum/Thread-Wheels-and-tyres
  Steering wheel angle, esp, power Steering smoky-jr 3 7,506 6:th-Jun-2021, 18:23:26
  Broken wheel stud Euroshopper 1 3,766 6:th-Oct-2020, 07:08:18
  Steering wheel from Astra K foxydimsi 2 6,909 1:st-Oct-2020, 06:49:56
  GTC limited edition alloy wheel paint code Nathan191210 5 7,344 1:st-Aug-2020, 19:22:43
  2017 GTC Limited edition - Front wheel noise Nathan191210 4 6,633 12:th-Jul-2020, 07:37:10
  space saver wheel Gary13 5 7,287 24:th-May-2020, 19:02:57
Last Post: Gary13
  Centre Speaker Woes andyp 2 4,200 7:th-Mar-2020, 12:07:10
Last Post: andyp
  Squeak when turning steering wheel Rusty2009 12 25,532 12:th-Sep-2019, 21:45:35
Last Post: Boycey1969
  Lowering and wheel spacers twinpipes 1 4,395 28:th-Jul-2019, 08:43:33
  Astra VXR heated steering wheel THEHITMAN 26 28,577 10:th-Mar-2019, 09:34:44
