question wheel 20 quot
20" wheel question
I have been offered some 20" alloys in the corrwct fitment in exchange for the 19" incorrect fitment ones I was sold, only issue is tyres are 245/40r20 now I know they should really be a 35 profile the guys has them on his astra j estate without any rubbing will they fit my 5 doors hatch without rubbing till I can get some new tyres
astra j or gtc
a 35 profile would be better 40 could be pushing it a bit for the j
Assuming the Astra J chassis is the same, wheel arch size is the same, I have done a calculation based on changing my wheels to the ones you are considering and there isn't any problems. If you go to the same website you can compare your current wheels to the ones you are looking at...
http://www.wheel-size.com/calc/?wheel1=2...0mm&sr=0mm
On my GTC 2.0CDTi 165bhp the correct size is 235/45R19 and therefore 245/40R20 is the right size for my car. And that is what I am running with no issues
  Steering wheel angle, esp, power Steering smoky-jr 3 7,038 6:th-Jun-2021, 18:23:26
  Broken wheel stud Euroshopper 1 3,530 6:th-Oct-2020, 07:08:18
  Steering wheel from Astra K foxydimsi 2 6,574 1:st-Oct-2020, 06:49:56
  DPF Regen question SectorOMEGA 16 17,127 9:th-Sep-2020, 16:10:35
  GTC limited edition alloy wheel paint code Nathan191210 5 6,957 1:st-Aug-2020, 19:22:43
  2017 GTC Limited edition - Front wheel noise Nathan191210 4 6,232 12:th-Jul-2020, 07:37:10
  space saver wheel Gary13 5 6,935 24:th-May-2020, 19:02:57
Last Post: Gary13
  diesel question niteram 13 11,313 29:th-Mar-2020, 09:48:59
  Squeak when turning steering wheel Rusty2009 12 24,710 12:th-Sep-2019, 21:45:35
Last Post: Boycey1969
  Lowering and wheel spacers twinpipes 1 4,203 28:th-Jul-2019, 08:43:33
