mp3 aux cd400 issues
CD400 Aux issues (MP3)
Does anybody know why my USB/AUX port would not work?
I first tried plugging in a small USB hard drive (always worked with my old head units) and now I've tried a 16gb SanDisk Cruzer Force (just with 4 MP3 albums on it) and it always says something like 'no aux devices detected'
It's a CD400 head unit and the car is only 1 year old......and its super annoying
Regards,
Neill
GTC [1.6 CDTi 16V SS ecoFLEX Limited Edition]
Has it ever worked?
It could be anything stopping it working if the is a year old take it back as you should still have warranty and let them fix it.
(2:nd-Jun-2016, 10:06:27)Rusty2009 Wrote: Has it ever worked?
I've only had the car a month, first time I've tried to use it.
But yeah it's still got 2 years warranty so I'll take it in and get it looked at.
Regards,
Neill
Ok sorry I thought you were 1st own.
So it could of had a USB retrofited.
If you want to have a look here is the retrofit guide
https://www.vxoc.org.uk/download/VXOC%20...397904.pdf
(2:nd-Jun-2016, 10:30:21)Rusty2009 Wrote: Ok sorry I thought you were 1st own.
Thanks for the info, will take a look but I doubt it was retrofitted as the car is an Ex Demo vehicle from VX main dealer.
Regards,
Neill
I think you are limited to size, number of tracks and folders .
I have a 32Gb USB , but over 1000 tracks , it didn't work - when I reduced the number of tracks to under 1000 and no folders it worked fine.
(2:nd-Jun-2016, 11:52:22)GOKIWI Wrote: I think you are limited to size, number of tracks and folders .
I'm trying 4 albums (in folders)
I'll go and try it now with flat files and let you know.
(It's pretty crap if it doesn't support folders.......I can see 3rd Party ICE happening )
@GOKIWI Doesn't work with flat files either, maybe it doesn't like the memory stick, I'll try a different make and then take it to my local dealer (I hate Main Dealers.....)
Regards,
Neill
Did you format the usb drive before adding the files...
I have a cruzer usb inserted and it works fine with folders, have you clicked on the aux button twice, as it has two sources (usb & aux). It should automatically select whatever is plugged in when you press aux button but you never know, you may need to press it again for it to see the usb device.
Have you tried the aux in port to see if that's working? If it is, you could quickly remove the dashboar trim around the head unit and pull the outlet socket out and see if the cable is inserted correctly at the rear, it only takes about 10 minutes if that.
(2:nd-Jun-2016, 13:17:44)stigeye Wrote: Did you format the usb drive before adding the files...
Ok brain fart time.....it was formatted for NTFS and not FAT32, must have used it for some HD movies in the past.
Re-formatted as FAT32 and it all works fine......I'll crawl back in my hole now
Regards,
Neill
  CD400 power problem bigles 6 8,298 22:nd-Dec-2020, 05:56:33
Last Post: bigles
  Insignia CD400 DAB Issues Dud2020 2 4,234 9:th-Dec-2020, 04:40:11
Last Post: Dud2020
  CD400 upgrade. Hemihunter 2 4,641 11:th-Nov-2019, 09:56:57
  cd400 to cd500 wiring ??? tzr608 12 22,808 15:th-Feb-2019, 18:18:23
Last Post: modoncity
  cd400 vs navi600 niteram 7 10,944 27:th-Aug-2018, 09:02:10
  cd400 wiring pin for 2 aerial amplifiers power tzr608 1 15,310 18:th-Jul-2018, 07:13:42
  Cd400 folder error display Fennmeister 4 8,965 11:th-Apr-2018, 09:14:47
Last Post: Fennmeister
  How to fit sub and amp to cd400 1.4turbo 1 7,361 9:th-Apr-2017, 09:13:30
  Middle Speaker on 2015 CD400+ srea064 8 15,661 10:th-Sep-2016, 00:11:36
Last Post: srea064
  Middle Speaker on 2015 CD400+ srea064 1 10,528 7:th-Sep-2016, 17:21:07
Last Post: bhalay207
adam@adamkimber.net (23:rd-Oct-2025, 16:32:13)
