middle 2015 cd400 on speaker
Middle Speaker on 2015 CD400+
Please can someone tell me if it's an easy job to wire in the middle front speaker on the later cars with the CD400 +?
I've got the speaker, just need advice on wiring it in please.
Steve
The oem wiring should already be there. It may be taped up behind the dash somewhere
I'll have to have another look as I couldn't see them when I first checked.
Thank you for your reply.
You must have to take the stereo and display out to find it.
No problem.
Have a look at the how-to i did it shows where the speaker plug should be
https://www.vxoc.org.uk/forum/Thread-how...e-speakers
Thanks guys,
I'll have another look this weekend.
Thanks for the replies...I found it!
It was well hidden away but as suggested, I pulled the radio and screen out of the way and had a good route around.
Glad you've found it mate. It does make a difference surprisingly
Funnily enough my last car, 63 plate GTC SRi 1.6 T, had the middle speaker and the sound was definately better.
2015 VXR with CD400+ never sounded as good. After reading various posts I discovered Vauxhall dropped the front middle speaker, I took a look under the speaker cover and found a hole instead.
That's why I decided to fit it, hoping the sound will now be better. Anyone wanting to improve the sound from the later cars fitted with the CD400+ should invest in the middle speaker!!
The wiring is definately there.
  Speaker wiring info Rusty2009 1 10,434 20:th-Feb-2023, 14:40:24
Last Post: Valentin
  CD400 power problem bigles 6 8,214 22:nd-Dec-2020, 05:56:33
Last Post: bigles
  Insignia CD400 DAB Issues Dud2020 2 4,190 9:th-Dec-2020, 04:40:11
Last Post: Dud2020
  CD400 upgrade. Hemihunter 2 4,626 11:th-Nov-2019, 09:56:57
  cd400 to cd500 wiring ??? tzr608 12 22,725 15:th-Feb-2019, 18:18:23
Last Post: modoncity
  cd400 vs navi600 niteram 7 10,907 27:th-Aug-2018, 09:02:10
  cd400 wiring pin for 2 aerial amplifiers power tzr608 1 15,265 18:th-Jul-2018, 07:13:42
  Cd400 folder error display Fennmeister 4 8,883 11:th-Apr-2018, 09:14:47
Last Post: Fennmeister
  How to fit sub and amp to cd400 1.4turbo 1 7,323 9:th-Apr-2017, 09:13:30
  Middle Speaker on 2015 CD400+ srea064 1 10,515 7:th-Sep-2016, 17:21:07
Last Post: bhalay207
Jonas Lythje (16:th-Jan-2026, 08:16:57)
