cd400 upgrade
CD400 upgrade.
Hi all. I've just joined the group and have just bought a 2013 GTC SRI 1.6 Turbo. I have a question about the entertainment centre. I don't know if this subject has been covered before as, like I say, I've just joined. Ok, I have the CD 400 system and even though it has a DAB radio, according to the manual, it doesn't have Bluetooth connectivity for a phone etc. Is this something that can be upgraded and what is needed to complete the swap. Many thanks for any help or advice offered.
have you tried the DAB on the radio, as most didn't have it fitted as standard
you would need the bluetooth module and the radio unit needs programming to make it work
Rusty2009 should be able to sort you out with the programming
Most GTC come with DAB & USB.
BT can be fitted but the radio does need programming, I can do this via post or in person (I'm based in Bournemouth).
Parts needed are the BT module with bracket. a BT loom (which I make) & a MIC (which is incl in the BT loom).
  CD400 power problem bigles 6 7,938 22:nd-Dec-2020, 05:56:33
Last Post: bigles
  Insignia CD400 DAB Issues Dud2020 2 4,048 9:th-Dec-2020, 04:40:11
Last Post: Dud2020
  IPC upgrade problem coabacje 0 5,540 11:th-Jan-2020, 18:58:54
Last Post: coabacje
  cd400 to cd500 wiring ??? tzr608 12 22,192 15:th-Feb-2019, 18:18:23
Last Post: modoncity
  cd400 vs navi600 niteram 7 10,600 27:th-Aug-2018, 09:02:10
  cd400 wiring pin for 2 aerial amplifiers power tzr608 1 14,994 18:th-Jul-2018, 07:13:42
  How to upgrade car radio? David Lee 1 6,921 5:th-Jul-2018, 06:44:01
  Cd400 folder error display Fennmeister 4 8,610 11:th-Apr-2018, 09:14:47
Last Post: Fennmeister
  How to fit sub and amp to cd400 1.4turbo 1 7,126 9:th-Apr-2017, 09:13:30
  Middle Speaker on 2015 CD400+ srea064 8 15,292 10:th-Sep-2016, 00:11:36
Last Post: srea064
jas7c5-2008 (4:th-Jan-2026, 17:47:29)
