Trade Count:
( 0)
Threads: 11
Thanks Received: 0 in 0 posts
Thanks Given: 0
0
Car: 1.6 CDTi 16V ecoFLEX Ltd Ed
Sex: Male
Total Feedback: 0
Does anybody know why my USB/AUX port would not work?
I first tried plugging in a small USB hard drive (always worked with my old head units) and now I've tried a 16gb SanDisk Cruzer Force (just with 4 MP3 albums on it) and it always says something like 'no aux devices detected'
It's a CD400 head unit and the car is only 1 year old......and its super annoying
Regards,
Neill
GTC [1.6 CDTi 16V SS ecoFLEX Limited Edition]
Trade Count:
( 4)
Threads: 359
Thanks Received: 4 in 4 posts
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
Has it ever worked?
It could be anything stopping it working if the is a year old take it back as you should still have warranty and let them fix it.
Trade Count:
( 0)
Threads: 11
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
(2:nd-Jun-2016, 10:06:27)Rusty2009 Wrote: Has it ever worked?
I've only had the car a month, first time I've tried to use it.
But yeah it's still got 2 years warranty so I'll take it in and get it looked at.
Regards,
Neill
Trade Count:
( 4)
Threads: 359
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
Ok sorry I thought you were 1st own.
So it could of had a USB retrofited.
If you want to have a look here is the retrofit guide
https://www.vxoc.org.uk/download/VXOC%20...397904.pdf
Trade Count:
( 0)
Threads: 11
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
(2:nd-Jun-2016, 10:30:21)Rusty2009 Wrote: Ok sorry I thought you were 1st own.
Thanks for the info, will take a look but I doubt it was retrofitted as the car is an Ex Demo vehicle from VX main dealer.
Regards,
Neill
Trade Count:
( 0)
Threads: 15
Thanks Given: 0
0
Car: 2014 Astra J
Sex: Undisclosed
Total Feedback: 0
I think you are limited to size, number of tracks and folders .
I have a 32Gb USB , but over 1000 tracks , it didn't work - when I reduced the number of tracks to under 1000 and no folders it worked fine.
Trade Count:
( 0)
Threads: 11
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
2:nd-Jun-2016, 12:23:33
(This post was last modified: 2:nd-Jun-2016, 12:45:10 by neilll.)
(2:nd-Jun-2016, 11:52:22)GOKIWI Wrote: I think you are limited to size, number of tracks and folders .
I'm trying 4 albums (in folders)
I'll go and try it now with flat files and let you know.
(It's pretty crap if it doesn't support folders.......I can see 3rd Party ICE happening )
@ GOKIWI Doesn't work with flat files either, maybe it doesn't like the memory stick, I'll try a different make and then take it to my local dealer (I hate Main Dealers.....)
Regards,
Neill
Trade Count:
( 0)
Threads: 9
Thanks Given: 0
4
Car: Astra 2.0 CDTi 165 VX Line S/S
Sex: Male
Total Feedback: 0
2:nd-Jun-2016, 13:17:44
(This post was last modified: 2:nd-Jun-2016, 13:22:48 by stigeye.)
Did you format the usb drive before adding the files...
I have a cruzer usb inserted and it works fine with folders, have you clicked on the aux button twice, as it has two sources (usb & aux). It should automatically select whatever is plugged in when you press aux button but you never know, you may need to press it again for it to see the usb device.
Have you tried the aux in port to see if that's working? If it is, you could quickly remove the dashboar trim around the head unit and pull the outlet socket out and see if the cable is inserted correctly at the rear, it only takes about 10 minutes if that.
Trade Count:
( 0)
Threads: 11
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
Regards,
Neill
