Trade Count:
0 )
Threads: 22
Thanks Received:
0 in 0 posts
Thanks Given: 0
0
Total Feedback: 0
28:th-May-2015, 09:01:22
(This post was last modified: 28:th-May-2015, 09:03:32 by dutton84 .)
Is it possible to buy new bolts that hold the engine cover on? Some of mine are rusty as hell. Had a quick look online and can't seem to find much
Engine cover bolts that should be.
Trade Count:
4 )
Threads: 359
Thanks Received:
4 in 4 posts
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
Engine cover just clips on mate (at least on the 2.0CDTI anyway)
Trade Count:
0 )
Threads: 22
Thanks Received:
0 in 0 posts
Thanks Given: 0
0
Total Feedback: 0
28:th-May-2015, 09:10:59
(This post was last modified: 28:th-May-2015, 09:18:26 by dutton84 .)
Ha. Oh.... Let me have a look. I just had a quick look and assumed that was there job.... 2 min.
Them to rusty bolts there
Trade Count:
4 )
Threads: 359
Thanks Received:
4 in 4 posts
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
What engine you got mate?
Trade Count:
0 )
Threads: 22
Thanks Received:
0 in 0 posts
Thanks Given: 0
0
Total Feedback: 0
1.6 turbo
Trade Count:
4 )
Threads: 359
Thanks Received:
4 in 4 posts
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
Just looked on EPC and it would appear they class your's as a cylinder head cover rather than an engine cover.
Now if I'm right the part numbers will be
24440095 -SCREW, TORX, M6 X 30, COVER TO CYLINDER HEAD
55355420 -SCREW, TORX, M6 X 21, COVER TO CYLINDER HEAD
Trade Count:
0 )
Threads: 22
Thanks Received:
0 in 0 posts
Thanks Given: 0
0
Total Feedback: 0
Cheers mate. Couldn't log on for a while laptop or on my phone.
Where would I buy them from? Put the part number in google comes up with GM in America
Trade Count:
4 )
Threads: 359
Thanks Received:
4 in 4 posts
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
Try your dealer mate or autovaux
Yeah something happened on the hosting side all fixed now.
Trade Count:
0 )
Threads: 22
Thanks Received:
0 in 0 posts
Thanks Given: 0
0
Total Feedback: 0
28:th-May-2015, 12:22:26
(This post was last modified: 28:th-May-2015, 12:23:16 by dutton84 .)
Just put the part number in autovaux
Take it they'll let me know how much they are before I order?
Trade Count:
2 )
Threads: 220
Thanks Received:
0 in 0 posts
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
you need the correct torque also for them and replace one at a time do not over tighten these bolts
Trade Count:
4 )
Threads: 359
Thanks Received:
4 in 4 posts
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
they are £1.30 but you need to add P&P on top mate I'd of thought that would be a 50p ish.
Trade Count:
0 )
Threads: 22
Thanks Received:
0 in 0 posts
Thanks Given: 0
0
Total Feedback: 0
Ok cheers. One more thing. Is there 2 different sizes, with there being to different part numbers.
I only really need 2 but I'd replace them all with them being cheap (just noticed the price)
Trade Count:
4 )
Threads: 359
Thanks Received:
4 in 4 posts
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
yes mate there are different sizes although EPC is not very clear on where they all go or how many of each are needed.
Trade Count:
0 )
Threads: 22
Thanks Received:
0 in 0 posts
Thanks Given: 0
0
Total Feedback: 0
I'll just take one of the rusty ones out and measure it against the new ones then.
Think I'll just order 4 of each size can't go wrong then
Thanks for your help.
Trade Count:
0 )
Threads: 7
Thanks Received:
0 in 0 posts
Thanks Given: 0
0
Car: Astra J Sports Tourer SE 1.3 Cdti
Sex: Male
Total Feedback: 0
As said you need to torque these correctly... there's usually an order to torquing them up also to ensure even tightening.
Don't want to end up leaking oil from the rocker cover.
Trade Count:
0 )
Threads: 22
Thanks Received:
0 in 0 posts
Thanks Given: 0
0
Total Feedback: 0
Mmmm..... Doesn't seem like a straight forward thing to do then.
Can I not just take one out, then just put a new one its place at the correct torque. Cants go wrong then surly?
Trade Count:
0 )
Threads: 22
Thanks Received:
0 in 0 posts
Thanks Given: 0
0
Total Feedback: 0
29:th-May-2015, 09:28:49
(This post was last modified: 29:th-May-2015, 09:29:38 by dutton84 .)
I've bought 2 x 201 bolts which are part number 24440095. Because I think they are the ones that are rusty on my engine
£3.62 each
Trade Count:
2 )
Threads: 220
Thanks Received:
0 in 0 posts
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
you can swap them one at a time but use the correct torque there not as tight as you may think
if you were to take the cover off then you would have to tighten them up in sequence
this is to protect the gasket
Trade Count:
0 )
Threads: 22
Thanks Received:
0 in 0 posts
Thanks Given: 0
0
Total Feedback: 0
Ok. Cheers. How do I find out what torque they're set to?
Trade Count:
2 )
Threads: 220
Thanks Received:
0 in 0 posts
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
rusty can you find that out mate
but you could check the torque of an existing bolt
that should point you in the right direction
Trade Count:
0 )
Threads: 22
Thanks Received:
0 in 0 posts
Thanks Given: 0
0
Total Feedback: 0
Oh yeah never thought of that. Need to arm myself with a torque wrench 1st. More money. Ha.
