black under cap won coolant filter t budge
Black filter/cap under coolant cap won't budge
When I unscrew the cap to the coolant tank there's a black cap or filter there that won't come out, coolant won't seep through it either so I can't put any in.
That's strange can you get a picture?
https://i.imgur.com/jkPeoRX.jpg This is is under the cap.
That looks like it's separated from the cap it's self as it shouldn't be there, you will need to get it out.
That what I was thinking, should I get some pliers and pull it out?
Yes pliers should work.
Yeah that's worked thanks Rusty, I was able to click that black bit of plastic into the cap. It was basically the seal to keep the pressure I believe.
Cool glad that's sorted.
Bleeding coolant liquid pipe kebagwan 3 5,358 22:nd-Sep-2019, 07:04:31
  Engine Coolant and remote locking dm1996 1 5,904 14:th-Nov-2018, 10:19:53
  GTC Coolant temp sensor chris_yorks 2 7,395 11:th-Jul-2017, 07:38:42
  coolant issue Shorty S91 5 9,310 8:th-Jan-2017, 22:51:27
Last Post: stigeye
  Diesel particle filter Lewis6317 3 7,728 14:th-Jan-2015, 11:57:05
