DRL cover (cap) .. I've lost it :(
I was switching over my DRL's on Sunday afternoon upgrading them to PolarG's and I assumed that I had securely put on the cap, only noticing after washing the car my headlight had condensation inside.. I must not have put the cap on properly and it's dropped out the engine bay and is currently in destination unknown..
Where can I get a spare?!
Black filter/cap under coolant cap won't budge
When I unscrew the cap to the coolant tank there's a black cap or filter there that won't come out, coolant won't seep through it either so I can't put any in.
Centre cap - 19" turbine alloys
Alloy Bolt cap size?!?!?!
Anyone no what size caps I would need to go over my alloy wheel Bolt (and locking Bolt) I have an astra gtc 1.7cdti with 18 inch wheels?
James
Sent from my HTC 10 using Tapatalk
fezza37 - Replies:
Gunk on oil cap
Hi Guys,
Sorry this isn't Astra related, My wife's Corsa has gunk on the oil cap like in the you-tube video below, its not loosing coolant its only driven 3 miles to work and back, i have done an oil and filter change but its still on the cap.
in the past couple of years its had the cam belt done the head skimmed, as said its not loosing any water from the bottle,
is this OK? what should i do?
thanks
example of what it looks like below
https://www.youtube.com/watch?v=pwgk255nTjA
ma444 - Replies:
Replace windscreen washer bottle cap
I have broken the cap to the washer bottle. I can see that there's a plastic ring which holds it onto the bottle - how do I get the thing off to replace?
