rain light sensor
Rain Sensor/Light Sensor
Hi Guys,
Wonder if anyone can help, I seem to be having what I think is an issue with the light/rain sensor in the Astra J. Not sure if its the sensor thats at fault, something else or not a fault. The issue is with the automatic headlight function, sometimes like today I started the car and it proceeded to put the headlights on even though its clear sunny day and the car is in direct sunlight. Other occasions i've had it when washing the windscreen it would come on and they would stay on for a good while, same with going in and out of tunnels the lights come on but seem to take forever to turn off or not at all & I have to manually turn the control off. I think i'm starting to notice it more due to the fact that it never use to behave in this way.
If anyone could shed any light on the issue (no pun intended there! Honest) it would be appreciated.
Auto lights are pain in the butt drive on dull day they work 100% spot on but as soon as we have some sun they never seem to want to turn off.
I spent over a year back and forth to dealer and arguing with VX over it they did start to work on an update but then dropped it.
All they need to do is tweak the lux settings and the system would work 100% all the time but they are too stupid to understand this
So its not just me then?. Cheers for the info rusty much appreciated. Ill just put up with switching them off when they should not be on. :/
That's what Vauxhall told me to do.
I said that does not solve the issue & I shouldn't have to.
I agree, otherwise what's the point in having the option?
I don't think it's limited to just Vauxhall. The Toyota Rav 4 I had as a courtesy car whilst mine was in the bodyshop had the same issue. Blazing sun but the lights would stay on. If I turned them off and then back to auto they would stay off. Weird!
(30:th-Sep-2016, 09:01:24)bhalay207 Wrote: I agree, otherwise what's the point in having the option?
Thats what happens in my J, if I switch them off manually for a while and then back on to Auto they stay off until the next time it thinks its dark when it really isnt.
Funnily enough I was in my brothers DS3 today and it was doing the same thing. I switched them off and back to auto and they stayed off. I'm guessing it's auto lights as a whole
the light sensors in street lights are much better they always no when it is dark haha and light
(30:th-Sep-2016, 20:18:32)tucpal Wrote: the light sensors in street lights are much better they always no when it is dark haha and light
Street lights are done on a timer that's why.
But on another note if my lights wont turn off only way to get them off properly is to turn the car off and remove the car and that doesn't work all the time.
timer maybe vauxhall use one haha but streetlights dont
https://www.google.co.uk/url?sa=t&rct=j&...YhDatoIL3A
Glad im not going mad then! I probably notice it more now I have pocket lights and the M072 headunit. As the unit screen dims a lot and the pocket lights come on when the headlights come on.....
  Clean DPF - O2 sensor location Henhead78 1 124 24:th-Apr-2026, 17:31:05
  Brake pedal sensor learn. Richiew1986 0 3,013 22:nd-Jul-2021, 16:53:31
Last Post: Richiew1986
  parking sensor Qaranc 1 3,880 8:th-Feb-2021, 01:33:43
Last Post: loeb
  Coolant light coming on when coolant is full (new sensor and no leaks) baffling me! Brasseyebaby 3 8,128 2:nd-Feb-2021, 21:12:47
  Glowplugs with pressure sensor or not Euroshopper 3 5,737 2:nd-Nov-2020, 16:01:21
  DPF REGEN LIGHT Starie 113 148,053 19:th-Apr-2020, 21:00:20
Last Post: Multiskilled
Spanner Light illuminated with engine off Wwood1991 2 5,967 11:th-Feb-2020, 13:01:57
  DPF pressure sensor richardhmorgan1 3 7,008 24:th-Sep-2019, 20:08:31
Last Post: Saunter
  Rear Light Replacement (Need Advice) A.ROD 2 7,518 17:th-Dec-2018, 19:17:48
Last Post: A.ROD
  Help engine light Mspencer 12 17,123 18:th-Mar-2018, 17:17:36
Last Post: Mspencer
