door d pin req info loom
Door loom pin info req'd
Anyone know where to get the pins for the door pillar connector, mirror switch connector and mirror connector in the front door looms
there were a few links in the how to
but i think one was not found
rusty found a few
Looked at the links and there's a minimum buy costing nearly £20 for the door connector alone
That's the problem mate most pins are in a minimum order, ask ***** if he has any for the door mate I got a few from him before.
Thanks mate will do or I might just buy a loom from ebay
thats what i did one drivers side loom will give you all the pins you need
  wiring info niteram 2 5,172 17:th-May-2020, 14:19:45
  vxdiag info Maniacu 7 10,579 6:th-Jun-2019, 07:23:11
  Technical (electrical?) info needed for the DVD800 radio and HVAC control panel i.rosca 1 12,183 22:nd-Jan-2019, 09:51:25
  Door Drain Plug THOMAS123 4 8,788 12:th-Dec-2017, 08:26:31
  Caliper Info tommyboy1289 1 7,321 13:th-Apr-2017, 22:15:00
  Need info on bulbs or links please :) Kris 34 32,658 13:th-Jan-2016, 19:38:38
Last Post: cornishtaz
  Part number for N/S interior door handle Morgan 5 9,586 6:th-Oct-2015, 05:28:55
  Trim running up the door handle Dman86 11 13,316 6:th-Oct-2014, 08:36:00
  Torque setting info Cameron UK 3 7,763 24:th-Jul-2014, 16:43:47
ScubaTroopa (5:th-Oct-2025, 23:32:24)
Users browsing this thread:
