door up running the trim handle
Trim running up the door handle
Hello guys,
I've looked around the forum and all over eBay and couldn't find anything about the following.
I'm looking for the sliver trim running up the door handle.
On my right door, it's a bit scratched and lost some color.
Any ideas where to get a new one?
I'm talking about this:
[ATTACH=CONFIG]244[/ATTACH]
Thanks a lot in advance,
Dima.
http://www.autovaux.co.uk/product/13409816-cover.aspx
Do you have the link for the vent surrounds and rear door trims?
[ATTACH=CONFIG]245[/ATTACH]
[ATTACH=CONFIG]246[/ATTACH]
ill look later mate what colour do you want?
what trim on rear door you need?
Not bothered about colour as it's going to be painted/hydro dipped . The handles on the rear doors.
Cheers Rusty
Do you have climate control mate?
Thank you Rusty. Unfortunately they are out of stock. How exactly do I know that it is the product without a photo or a description?
Added pictures above of what I'm after. Trim rounds for vents and rear handles for both sides.
WhelanUK they come complete mate you can't get the fascia plate separate so I need to know if you have climate control or not. for the air vents
RH Rear Door Trim 13411294 http://www.autovaux.co.uk/product/13411294-cover.aspx
LH Rear Door Trim 13411293 http://www.autovaux.co.uk/product/13411293-cover.aspx
Dman86 most of there items are not stocked by them they get them from Vauxhall some are even sent direct from the vauxhall dealership.
The part I linked to matches that in my photo you used to show what part you wanted I have access to Vauxhall EPC and can get part numbers I get the following show up.
[Image: EPC.PNG]
Wow, I'm impressed - I'll order it soon.
Thanks a lot mate.
I don't have climate control. Got a feeling I'll prob be easier getting second hand vents then ordering a whole new trim set.
LH air vent 13300540 http://www.autovaux.co.uk/product/133005...utlet.aspx
RH air vent 13417611 http://www.autovaux.co.uk/product/134176...utlet.aspx
You would be better off getting 2nd hand ones mate TBH.
  Boot trim clip leighton.read@sky.com 2 4,559 9:th-Jul-2020, 10:07:00
Last Post: leighton.read@sky.com
  Door Drain Plug THOMAS123 4 8,820 12:th-Dec-2017, 08:26:31
  Centre console trim removal goodymk6 1 5,843 1:st-May-2016, 22:17:20
  Part number for N/S interior door handle Morgan 5 9,622 6:th-Oct-2015, 05:28:55
  Window trim tucpal 4 7,359 20:th-Jun-2015, 09:56:05
  Door loom pin info req'd cornishtaz 5 8,918 4:th-Apr-2015, 23:07:16
