wrapping diffuser the vinyl rear
Vinyl wrapping the rear diffuser
Do people think this is possible or will it require painting want to make mine gloss black
i have seen someone do it a GTC
but looking at the VXR i would say paint will be the best option
it should cost around £100 from a paint shop and the finish will be better than doing it your self
Me and @wheelanuk are going to be doing his, it will work but may need preparing for the vinyl to adhere properly, just sanding down, is the vxr the same material as the 5 door?
I believe its the same but it has fins unlike the 5 door
Get it hydro dipped
Agreed there hydro dip is a good idea
Good shout. Will see if I can find somewhere local and if not might just attempt it myself.
Ive had my rear insert wrapped gloss black, Cost me £30.
  Lowering springs identify front rear martinpe68 1 4,184 12:th-Sep-2021, 15:22:37
  Astra J Rear Bench Seat Clip. MrScottyMan 1 7,184 24:th-Jan-2021, 14:44:22
  Rear diffuser Elad1962 3 5,298 29:th-Sep-2020, 22:14:18
  BiTurbo Rear Bumper Dudderz 3 6,949 5:th-Jun-2020, 19:49:44
  Rear Bumper PN 13346637 Jonnymac07 1 4,055 13:th-May-2020, 14:56:05
Last Post: paula9568
  Rear brake pads and discs everson38 4 7,031 28:th-May-2019, 10:53:57
  electric rear windows marky79 5 7,556 11:th-Jan-2019, 09:04:32
  Rear Light Replacement (Need Advice) A.ROD 2 7,555 17:th-Dec-2018, 19:17:48
Last Post: A.ROD
  GTC water collects under rear window Canasta 2 7,328 30:th-Oct-2018, 22:23:04
Last Post: marky79
  Headrest for middle rear seat passenger benawhile 7 10,231 12:th-Oct-2018, 07:10:57
