to ipc hidden options turn dash how on
HOW-TO Turn on hidden options on IPC (DASH)
Before
[Image: Standard.jpg]
After
[Image: Moded.jpg]
Before
[Image: Stanard%202.jpg]
After
[Image: mod%20full.jpg]
Quote:Trip computer 10 min job to activate. They have to SPS the dials on "configuration and setup" set all to default to save time looking up the RPO codes then look for "driver information center" then change it to "yes" this will originally be set to "no" when "SET TO DEFAULT" has been entered.
On the later cars the sensor for both the header tank and washer bottle are missing and will bring CODE 3 and 174. If you make a bridge for the two pins on the plug the codes will go away. Unless you want to fit a new header tank and washer bottle with the sensors in.
Here is video incase you go to a dealer and they don't understand.
[video=youtube_share;sdpk_N2HkHY]http://youtu.be/sdpk_N2HkHY[/video]
If you have or know someone with a Vaux-com it is much easier (I sold my Vaux-com)
[Image: hidden.png]
[Image: hidden1.png]
[Image: hidden2.png]
[Image: hidden3.png]
[Image: hidden4.png]
[Image: hidden5.png]
Here we have the half display
[Image: attachment.php?aid=704]
[Image: attachment.php?aid=705]
[Image: attachment.php?aid=706]
[Image: attachment.php?aid=707]
i forgot to get you to do that for me
i am just missing the first 4 in the first one after reset
and the last 3 in the second after reset
Lol Do you have the same display as me?
I know I did this for [MENTION=25]Tottybye[/MENTION] & [MENTION=19]Lewis6317[/MENTION] using the Vaux-com and they had the smaller display and there is not as many for the small display.
different to you mate
menu 1
[Image: trip001_zps912b26e1.jpg]
[Image: trip002_zps5e371c98.jpg]
[Image: trip003_zpsd975c82b.jpg]
[Image: trip004_zps305de562.jpg]
[Image: trip005_zps2801416f.jpg]
[Image: trip006_zps97a95951.jpg]
[Image: pp001_zps7a5fd21b.jpg]
menu 2
[Image: trip009_zps994ae014.jpg]
[Image: trip008_zpsc6a1d0f8.jpg]
[Image: trip007_zpsc9a69b23.jpg]
Yeah there's not as many on that display.
Not sure if you can even get the Navi display on that one.
I never had fuel range! I want that lol well i lost all mine when i had usb fitted at trax
Yours is different to Tucpal's again mate.
Everything looks the same though? Whats differant about it mate?
I thought yours was laid out slightly different Lol but I know we didn't have the option to turn on the fuel range we got MPG though didn't we?
We did indeed mate just need to do it again lol
Hello to all forum....
Respect to your job mate, all I want is to ask you, if it is possible to active these secret menus to Astra J 1.4 2010 A14XER ?
Best Regards
Vaggelis
It depends what screen you have, if it's the smaller screen you will only get a few extra.
(18:th-May-2015, 18:40:21)Rusty2009 Wrote: It depends what screen you have, if it's the smaller screen you will only get a few extra.
Thank you very much for your answer and I wish a happy new Year, I wish you the best.
what extra do you think that we can enable to my small screen ? And how we can do it, cause I'm in Greece.
Best regards !!
MPG and iirc fuel range
i have a few different eco ones on the insignia
Yeah it's estimated MPG, miles till empty and I think you can have it so it records journeys (amount of miles in a journey till you reset it). But not use who you can get to do it in Greece mate! I got a local guy to do it...
Hi all would like to get this done on my Bi-turbo,
I have noticed a difference on my display i have no ECO,, is that right.??
Anyone in the Essex area you can do this??
thanks
James.
(20:th-Jul-2016, 09:13:35)jj120979 Wrote: Hi all would like to get this done on my Bi-turbo,
thanks
James.
You won't have eco as iirc the Bi-turbo doesn't have s/s.
No one in the Essex area that I know of.
Hi!
I've the factory parking sensors (Rear and Back) on my J Sports Tourer.
It's possible to add the option that shows the distance between the car and the obstacle, like this?
[Image: opel_astra_sport_tourer5416273800947943846-1024x768.jpg]
That depends on what display you have.
If they are factory fitted you would have the correct config for your car already.
My display is like tucpal showed few replies above:
https://www.vxoc.org.uk/forum/showthread...2#pid10382
I think it's factory fitted because the beep sound is on the speakers and two different sounds, one for the front sensors and another for the rear sensors.
Strange. The factory ones show the distance display. Or mine does anyway
It could be that the UD7 hasn't been turned on on the IPC.
(22:nd-Jul-2016, 06:44:22)Rusty2009 Wrote: It could be that the UD7 hasn't been turned on on the IPC.
Maybe this could be a dumb question... but.... it's possible to enable that using OPCOM or something...?
Thanks?
Thanks?
MDI only to turn that option on.
thanks
James.
thanks
James.
Mine has the ECO button and has stop/start,,
thanks
James.
Do you know of anyone in Manchester that can activate the trip computer by any chance?
2011 Astra J Excite with the small display
thanks
James.
thanks
James.
It could be they've issued a newer software / config files depending on what year it is and what options are fitted etc.
thanks
James.
No I don't sorry.
thanks
James.
thanks
James.
thanks
James.
No I don't sorry.
Can you do it if i come to you? If so how much?
Thanks again in advance
What display do you have?
I charge £15.
(22:nd-Aug-2016, 15:20:39)Rusty2009 Wrote: What display do you have?
I charge £15.
This looks like mine,
I can make out a lot of words in the LCD display but i only have millage and oil level.
Hope this helps
[Image: a.jpg]
I charge £15.
Hope this helps
[Image: a.jpg]
All you can get on that is 2 other options IIRC average MPG & MPH.
I charge £15.
Hope this helps
[img]data:image/jpeg;base64,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[/img]
I charge £15.
Hope this helps
[Image: a.jpg]
That's fine, anythings better than nothing. Ive sent you a PM,
Dan
Hi, new on here. I have a 60 plate 1.7 Astra j exclusiv with the small screen. Based in Manchester, is there anyone who can enable extra settings?
(25:th-Aug-2016, 21:23:22)Jordanclark666 Wrote: Hi, new on here. I have a 60 plate 1.7 Astra j exclusiv with the small screen. Based in Manchester, is there anyone who can enable extra settings?
Don't know anyone up that way sorry.
Nearest person to you I believe is vxmods at ellesmere port...
http://vxmods.co.uk/astra/astra-j-retrofits/
Brilliant, thanks guys!
No Andy doesn't have access to an MDI.
Wont Vauxhall themselves enable them... for a fee?
(26:th-Aug-2016, 10:51:51)stigeye Wrote: Wont Vauxhall themselves enable them... for a fee?
Haha don't make me laugh they don't do things like that nor would they know how.
Hi Guys,
Firstly, thanks to rusty for hooking my display up.
To clarify, i have the small display which only had millage and oil level.
Since Rusty turned on my options I now have:
Oil Level
Millage
Average Speed
Current (live) MPG
Average MPG
Thanks again,
Dan
(2:nd-Sep-2016, 11:35:17)mullet161 Wrote: Hi Guys,
Oil Level
Millage
Average Speed
Current (live) MPG
Average MPG
Thanks again,
Dan
I am new to this so please bear with me :-)
I as well have Astra Excite with small display. I am based in Northampton, do you guys know anyone who whould be able to unlock it for me, please. I could possibly travel.
Thanks a lot
Oil Level
Millage
Average Speed
Current (live) MPG
Average MPG
Thanks again,
Dan
Thanks a lot
I can unlock it based in Bournemouth, I used to live in Northampton but our friends have also moved out of the area so I have no need to go there any more.
Thanks for your reply Rusty. It's a shame you don't live in Northampton anymore. I'll first try to find somebody near me but if I don't find anyone I think I'll have to treat myself with a trip to Bournemouth then lol. Will be in touch.
Thanks again
Regards
Renata
Hi. I have 2011 astra j only thing displayed is milage. Anyone in north east that can't sort mine?
Much appreciated
also just a heads up when activating the hidden menus
avoid the compass setting it does nothing and by activating it
i lost my nav direction arrow menu
Oil Level
Millage
Average Speed
Current (live) MPG
Average MPG
Thanks again,
Dan
Thanks a lot
Hi Rusty,
I decided I'd like to have a trip down to Bournemouth lol. Would you please send me a PM to make some arrangements, please? I am limited to Sundays and only some Saturdays and not sure if that would suit you. As above I have Astra Excite 11reg with a small diplay (same as mullet161).
Looking forward to hearing from you.
Renata :-)
Hi im a new member with a sports tourer in tyne and wear area, is ther anyone close that could turn on my trip computer.
Closet to you would be Adam in Liverpool.
  Swap astra J dash display chrisscruton 6 13,228 25:th-Mar-2019, 10:16:12
Last Post: chrisscruton
  Hidden menus CD500,600,800,900 tucpal 4 26,503 2:nd-Apr-2014, 18:10:23
Last Post: Lewis6317
9 User(s) read this thread:
c4nny (16:th-May-2025, 23:56:51), Richard9716 (16:th-Jul-2025, 16:33:00), Buashei (4:th-Feb-2026, 13:23:37), ukimpact2009 (11:th-May-2025, 20:20:34), hookme (3:rd-Jun-2025, 04:53:29), TonyP (28:th-Aug-2025, 23:00:04), Steve1982 (8:th-Sep-2025, 20:30:42), ionutalexandru (17:th-Jan-2026, 21:11:59), lar77 (18:th-Feb-2026, 17:17:24)
Users browsing this thread:
