HOW-TO Turn on hidden options on IPC (DASH)
Extra menus on the Instrument Cluster (IPC)
How-to remove Instrument Cluster (IPC)
umognog - Replies:
Can anyone ELI5 why my IPC has 3 TC indicators?
Wondering if anyone can explain it like I am 5 why when I push TC off I get a bludgy-tyre with TC in it and a cross out. But there is also a drink-driver image just above it, and on the other dial a drink-driver image who is off that day?
Stupid questions I know, I think I know why but want to hear from others to validate or pretend that is what I thought all along.
gazz292 - Replies:
Change language of IPC
If i got an ipc that is almost exactly for my vehicle from poland... can the language the DIC / driver display is in be changed to english? i note my insignia ipc i'm using for now has no language settings, but i'm sure i read somewhere that there is a menu that can be activated that gives language selections.
obviously the speedo is in kph, but i'd swap my background card over to the mph version from my original ipc,
I'd be (hopefully) getting Rusty to work his magic on the IPC to make it w
marky79 - Replies:
ipc
hi all
does any one know or have any links on how to remove insignia ipc.
marky79 - Replies:
ipc
message for rusty2009, do you have any info for me on insignia on ipc
BL25 - Replies:
IPC Upper Display Speedo Upgrade
Hey everyone,
I've got an Astra J Excite with the lower IPC display. I wanted to buy a unit off eBay and fit it myself but ive done some research and undertstand it will need programming. I called vauxhall and asked if they could program it for me if i was to fit it and they said it's not possible, but I've read in the workshop manual that it could be programmed with the SPS programming device.
[attachment=1104]
[attachment=1105]
IPC upgrade problem
Hi folks, i got insignia 2.0 cdti 2009, and after some time i wanted to change ipc with mid level display for ipc with uplevel display. I read eeprom, changed my car vin and security code and all got working (odometer and no errors since ipc is from the same specs car like mine) but rev counter is staying at 0, although it does sweep at start. Is it some wiring issues or need more programing?
marky79 - Replies:
ipc pin out
does any one have a wiring pin out for the ipc
many thanks........
