to sensors fit reverse aftermarket how
How To: Fit aftermarket Reverse Sensors
(24:th-Jan-2017, 15:42:28)mart Wrote: It's ok now the error message has gone now, must of been a loose bulb or something.
Got my sensors this week and sprayed them up with silver lake metallic spray paint (see below). Will fit them this weekend it weather is ok.
[Image: 9f0ce77d8831354be39ccb7a8484de54.jpg]
Has anyone else sprayed there sensors with metallic paint?
Is it ok to use metallic paint, I forgot to check before I sprayed them?
Also should I spray with lacquer after?
i did on my vectra, worked a treat, i also lacquered them
All done now just got to stick the speaker in a good place, Anyone think of any ?And tidy up the cables a bit.
It was a bit tricky getting the bumper off. Trying to get the two clips off in the middle and the two clips under were the tail light was the trickiest.
[Image: 9a79cc0621b2d2a2c7dceeaf59c889f0.jpg]
[Image: 6074f3a5a9624e7d616af3531be58017.jpg]
[Image: 20649cc7f3481bd8165f6ee786ed19ed.jpg]
(27:th-Jan-2017, 15:19:56)mart Wrote: Tapped into the reverse light power today going to do the bumper tomorrow.
[Image: c852c7cce6405b0346fe2fea7ca7dc3b.jpg]
This is the wire i used behind the light in the boot compartment, so u don't have to run wires direct from the reverse light boot lid.
hi so the bit you tapped power from is where i have marked the red arrow?
That's it yes. The bunch of wires that come from the tail lights come down the rear pillar and are tapped into the were you highlighted. Just need to find the green wire with a white stripe.
(5:th-Feb-2017, 21:20:59)mart Wrote: That's it yes. The bunch of wires that come from the tail lights come down the rear pillar and are tapped into the were you highlighted. Just need to find the green wire with a white stripe.
Thanks i'll look into that this week,  i really didnt want to try and feed a wire down the boot lid so good job.
Which sensors did you go with?
Got these ones from eBay and sprayed them with the correct colour for my car.
https://www.ebay.co.uk/itm/361202311444
Did you laquer them?
Yea, 2 light coats of the paint then 1 light coat of the lacquer.
I Had a look today unwrapped the factory tape and i saw 2 green wires, the thickest one is the one you need if anyone needs to know , it is green / white stripe and i stuck a tester in and confirmed there is a 12v reverse feed in there.  Just got to wire it up next week.
(5:th-Feb-2017, 23:03:58)mart Wrote: Yea, 2 light coats of the paint then 1 light coat of the lacquer.
Where did you get the paint from mate?
Direct from the dealer. It was about £15, and came with one spray can of metallic paint and one spray can of lacquer.
Special order?
Sort of, I just called my local dealer and they told me I could pick it up and pay the next day.
You bought your sensors yet. Post some pics when you fitted them.
Not yet, waiting for the weather to get warmer, I did it on my old J [Image: 1ed315c371e5b9edcc4c1140a679b465.jpg]
Got mine on today, was easier than i thought.
(4:th-Jun-2015, 16:01:59)Jj0063 Wrote: Bugger it I've ordered the bottom link & will post how it goes lol.
How did you get on with the electromagnetic sensor, is it any good? Wouldn't mind trying one if they work well.
hi to all,
Great how to. Thank you very much. I want to install Valeo beep & park kit 1 parking sensors guided by this how to. Seller told me I need to pay attention when washing the car. Sometimes, after washing the car they are giving false alarm. Anyone has experience with this kind of sensors? How they are during rainy days?
(27:th-Jan-2018, 19:20:26)Brnjas Wrote: hi to all,
no  the sensors are waterproof, ive never had a false positive with mine.
Thanks mate,
already installed new Valeo kit 1 aft. For now on this freezing cold no issues. Not yet washed car. 'Cause too much mud on road.
Sent from my MI 5s Plus using Tapatalk
not sure if it's already been mentioned but the green and white wire needed to splice into is in the wiring loom just behind the fuse box on the left hand side of the car and is much easier to access than threading through everything to get to the reverse light in the rear door and using the bolt that attached the fuse box to the body is a good grounding source. I used scotch locks for my live to reverse wire and did the job in under 10 minutes.
  How to Install a Reverse Camera in an Astra J with Navi 900 Summit 22 35,947 22:nd-Feb-2021, 07:59:27
  Multimedia interface, reverse camera, navi 600, insignia, astra j. tucpal 5 21,314 10:th-May-2018, 16:03:16
Last Post: vocky
madgerald1974 (9:th-Sep-2023, 18:01:10), greg848484 (23:rd-Jun-2023, 19:40:54)
