lowering amp please widening advice
Lowering & widening advice please.
Hi Im thinking of going the Eibach Pro 30ml spring lowering kit route with my Gtc Sri 2ltr Cdti 3door 13 plate.
Also thinking of fitting Eibach pro wheel spacers. Has anyone had any experience with the springs, spacers, how wide to go, where to buy them and oh are they legal?
Many thanks from sunny Northumberland ??
My view on lowering is 10mm max anything else is too low I know others have lowered 30-40mm and are happy.
As to wheel spacers your be adding extra strain on the drive shafts.
Thanks for that Rusty, your advice is always appreciated and welcome.
(16:th-May-2017, 09:45:49)ronnierae Wrote: Thanks for that Rusty, your advice is always appreciated and welcome.
How well do your mud guards work? Thinking of getting some, cheers
Best thing I ever did fitting mud flaps doesn't totally stop it but helps alot.
Without getting too technical, assuming you are keeping the same wheels.
I reckon you would have a maximum of around 20mm to play with between your rim and wheel arch for spacers. Of-course this is just a guesstimate, and your best bet is to put a piece of wood across your wheel arch and measure the gap between the inside edge of the wood and outer edge of your rim. You would also have to take into account tyre rim as these can protrude, depending on tyre make.
Most people who lower their GTC's do it on springs and pretty much the lowest you will get is 30mm. Even so, after lowering you will still have at least a good inch between top of tyre and wheel arch, so you will not have any issues with speed bumps or rubbing.
This is a gtc lowered on 30mm H&R springs with the same wheels as yours to give you an idea of the end result.
https://gyazo.com/d887a2f8e8dfecbab92937408efa7bd8
(16:th-May-2017, 22:20:35)stigeye Wrote: Without getting too technical, assuming you are keeping the same wheels.
Aye and also you will need to take into account when widening it is that your wheel cant be wider than your wheel arch (at the top) and tbh will 2cm really make it look that much different? I would save my money with my gtc
Thanks for that. jon, yeah Ive had a bit think about it and decided not to.. Many have said that it can put undue stress on bearings, shafts and suspension.. So have taken note of everyone's advice.. Can't really justify ruining a 3 year old car tbh.. Thanks for your help and advice guys.
(17:th-May-2017, 14:30:19)ronnierae Wrote: Thanks for that. jon, yeah Ive had a bit think about it and decided not to.. Many have said that it can put undue stress on bearings, shafts and suspension.. So have taken note of everyone's advice.. Can't really justify ruining a 3 year old car tbh.. Thanks for your help and advice guys.
Your very welcome aye would do all of that and also (due to broken back) a harder ride isnt comfy at all but it is a nice car though! I was going to get white but the red was just a better car
  DRIVER SIDE MIRROR NEED ADVICE caretaker 1 1,608 29:th-Jun-2025, 13:19:31
  Lowering springs identify front rear martinpe68 1 4,177 12:th-Sep-2021, 15:22:37
  Information Regarding Lowering My Astra J SAMW98SO 11 10,642 9:th-Sep-2020, 01:37:06
Last Post: M222RJF
  "Stop Vehicle Immediately Engine Has Overheated" Advice appreciated please Dennis S 25 55,681 30:th-Aug-2020, 13:56:18
Last Post: Rgotts00
  I bought a used GTC! - Fantastic car but a few issues i could do with advice about Mattymush 5 9,104 12:th-Jul-2020, 07:45:59
  VXR lowering springs hooper 3 6,855 5:th-Apr-2020, 08:30:10
  SVS - Battery advice shabba 2 4,969 2:nd-Mar-2020, 21:09:49
  Astra J 1.6cdti ecoflex lowering Alan300589 3 5,342 18:th-Feb-2020, 19:27:25
  Lowering and wheel spacers twinpipes 1 4,388 28:th-Jul-2019, 08:43:33
  Astra J lowering hooper 1 4,620 1:st-Jun-2019, 09:20:04
3 User(s) read this thread:
c4nny (26:th-Feb-2026, 10:58:46), Buashei (15:th-Mar-2026, 14:15:51), Griff81 (18:th-Apr-2026, 18:46:02)
