lowering j astra
Astra J lowering
Hi all
Picking up a 2013 2.0 CDTi Astra Elite on the weekend.
I am also planning on purchasing a set of 18" rims (GM# 13269540)
These are 225/40/R18
I want to drop the car a bit but not to a point that will ruin the ride. I live in the Cotswolds and the roads are bumpy as round here with a number of potholes.
Was thinking 30mm max.
Any suggestions on the rim and spring suggestion?
Thanks in advance all
IMHO 30mm is too low.
I would suggest dropping it 10mm get the SRI springs as they are 10mm shorter than standard springs, they also keep a nice smooth comfy ride.
GSF very often have upto 60% and you can pick up the rear springs nice cheap then.
Factory Rear springs are prone to breaking so I'd advise on these.
https://www.gsfcarparts.com/511gm1430
Buying from GSF when 60% offer is you get the 2 for less than the price of one.
For the front springs look on ebay.
  VAUXHALL ASTRA 1.7 CDTI FUEL SENDER UNIT 13272601- FUEL ERRATIC GUAGE BELWO HALF TAN caretaker 3 4,665 21:st-Oct-2024, 18:22:15
  Astra 1.6 CDTi Turbo Issues P2598 shaky411 1 7,606 12:th-Sep-2021, 15:24:05
  Lowering springs identify front rear martinpe68 1 4,132 12:th-Sep-2021, 15:22:37
  Vxr bumper on 5 door Astra j Sh4rk2007 10 15,045 6:th-Jun-2021, 18:25:04
  New Battery for Astra J 2013 reg 1.7 diesel Galway11 6 8,904 13:th-May-2021, 11:38:55
  Astra J 1.4T Exhaust help sammpennington 1 6,924 12:th-May-2021, 14:29:50
  Astra j gtc modifications BillyBryan 2 5,499 9:th-May-2021, 17:15:36
Last Post: Spaghetti
  Astra J Fault code reader suggestions Euroshopper 1 5,347 22:nd-Feb-2021, 08:50:12
  Astra j bonnet won't open help Paul in sheppy 2 5,443 17:th-Feb-2021, 13:13:46
Last Post: Paul in sheppy
  Astra J GTC PDC bracket milozic 5 7,101 2:nd-Feb-2021, 09:39:35
