battery svs advice
SVS - Battery advice
Very strange one this morning. Cranked it over and it appeared sluggish, eventually started. Immediately went into SVS mode. Limping along.
Mate said to try charging the battery then disconnect and reconnect and see if that works. Amazingly did this limping along with revs not going over 3k. Big mistake to take it along the A1 but there you go.
Disconnected the battery when I got back, left it for 45 mins. Car started normal with SVS & limp mode cleared.
So now Im after a new battery (fingers crossed this was the issue) conflicting info as to which battery I actually need.
The one in is a OEM GM AGM which Im guessing will be expensive so an aftermarket will do. Any ideas which one I should get.
Vauxhall Astra j 2.0 CDTI elite model 2014 with S/S. My S/S hasnt worked for well over 18 months so not sure if its needed or not battery wise.
Any advice?
Hi there,
Usually the s/s stop to work when the battery capacity is under 75% i think.
I changed mine with a VARTA Dynamic Blue AGM 80ah 800a I have it since December 2018 and it's still OK.
There are so many condition's for S/S to work.
I though my battery was at fault so bought a new s/s battery for £130ish trade and still had issues found it was my dashcam draining the battery.
  Dead Radio After New Battery Mr_Blogberry 1 706 26:th-Jan-2026, 08:48:09
  DRIVER SIDE MIRROR NEED ADVICE caretaker 1 1,603 29:th-Jun-2025, 13:19:31
  New Battery for Astra J 2013 reg 1.7 diesel Galway11 6 9,042 13:th-May-2021, 11:38:55
  "Stop Vehicle Immediately Engine Has Overheated" Advice appreciated please Dennis S 25 55,635 30:th-Aug-2020, 13:56:18
Last Post: Rgotts00
  I bought a used GTC! - Fantastic car but a few issues i could do with advice about Mattymush 5 9,077 12:th-Jul-2020, 07:45:59
  Rear Light Replacement (Need Advice) A.ROD 2 7,529 17:th-Dec-2018, 19:17:48
Last Post: A.ROD
  Tow bar advice Martz66 6 7,651 8:th-Nov-2018, 18:37:44
Last Post: Martz66
  Some advice Mspencer 9 9,121 22:nd-Dec-2017, 02:01:14
Last Post: Iaintruten
  GTC body kit, color advice needed twinpipes 3 8,023 5:th-Aug-2017, 12:03:36
Last Post: gregj
  Tire advice jdkm01 6 9,184 9:th-Jun-2017, 09:02:31
