removal emblem griffin rear
Rear Griffin Emblem Removal
Does anyone know if the rear Griffin Emblem badge is stuck on or clipped on? I really want to remove it.
it is stuck on with 3m tape but there is also two tabs on the griffin
so if you remove the badge there will be two tiny holes on the boot.
Are they very noticeable or will they have to be filled etc?
filled as they stand out
other option is to do the background black
but this only works on light color cars
My car is technical grey so it wouldn't make any difference. I've been told to use plasti dip to spray it.
you can do PlastiDip is fine but pealing the inlay bits out is not that easy.
[MENTION=52]Dicko[/MENTION] did his griffin black sure he Plastidip or wrap it.
Could I not remove it, respray it and then put it back on?
Yes but you will need sum new 3m tape to stick it back on but if you do remove it I recommend wrapping it for a better finish
I may just take it to the body shop for them to do.
You can buy a new one from eBay etc then spray or wrap the new one that way you have the tape already on the back just heat the old griffin with a hair drier and use an old credit card to get it off then remove the old tape that will be left over on the car and the griffin with silicone remover or tar remover
How did you do your background Tucpal?
i made a template from an old badge i had and then cut it out and then used the stencil on some gloss black wrap
To undo the tabs to take badge off how do you that? Is it the case of taking plastic of boot door inside?
  Lowering springs identify front rear martinpe68 1 4,088 12:th-Sep-2021, 15:22:37
  Astra J Rear Bench Seat Clip. MrScottyMan 1 7,099 24:th-Jan-2021, 14:44:22
  Easy removal of glowplugs? Euroshopper 1 5,488 13:th-Nov-2020, 16:21:11
Last Post: eatmybogbrush
  Rear diffuser Elad1962 3 5,209 29:th-Sep-2020, 22:14:18
  BiTurbo Rear Bumper Dudderz 3 6,817 5:th-Jun-2020, 19:49:44
  Rear Bumper PN 13346637 Jonnymac07 1 3,986 13:th-May-2020, 14:56:05
Last Post: paula9568
  Rear brake pads and discs everson38 4 6,910 28:th-May-2019, 10:53:57
  Small glove box removal chrisb2511 7 11,075 5:th-Mar-2019, 13:14:03
  electric rear windows marky79 5 7,385 11:th-Jan-2019, 09:04:32
  Rear Light Replacement (Need Advice) A.ROD 2 7,464 17:th-Dec-2018, 19:17:48
Last Post: A.ROD
