remote garage gate control
Gate garage remote control
Hi. I am from Czech republic and my English isn't good. Sorry. This forum is best for last Astra.
I would like connect my gate garage remote control to phone button on steering wheel. I can't find right pin on connector. I have not bluetooth, but button MUTE works. I have radio CD400. Gate garage remote control power baterry 12 V.
Have you any idea how to do it? Thank you.
[ATTACH=CONFIG]336[/ATTACH]
[ATTACH=CONFIG]337[/ATTACH]
I'll look later but i'm pretty sure there is only one signal wire which is used to send commands from the buttons
Right I've just checked and yes there is only 1 wire used to send the signals, you maybe able to tap into this but it might lead to problems. I hope the below will help.
Thank you Rusty! I will try to do some sensor for detection correct button. Where is hidden BCM - Body Control Module? I will make some measurements. I do not want airbag explosion, so I hope it is different connector :-D
Odesláno pomocí TAPATALK
The BCM is behind the kick panel in the drivers footwell (on RHD) so I think it will passanger footwell on LHD.
I will get the BCM pin outs for you over the weekend.
I have this information. It's connector x3 in BCM. The voltage is pin 4, the return signal is pin 8 (right of the steering wheel).
Know you what color has the connector x3? Thanks.
Green is 3 mate.
I thought so. I have little problem. Pin 4 is empty. My post mentioned above is incorrect. Have you any ideas or schema? :-)
I'll look tomorrow mate
What is the make of garage module you are using
  Anyone remote SPS? milozic 1 3,074 12:th-Sep-2021, 15:31:26
  remote issues Qaranc 5 5,204 20:th-Oct-2020, 08:28:26
  Heating / climate control iandy66 2 3,842 14:th-Sep-2020, 18:11:08
Last Post: iandy66
  remote issues Qaranc 8 6,595 21:st-Feb-2020, 10:34:30
Last Post: Qaranc
  Cruise control not working raimon 10 29,959 27:th-Nov-2017, 12:33:46
Last Post: AlanMac
  Climate control sensor SectorOMEGA 4 6,209 22:nd-Jul-2017, 08:35:22
  Pedal box remote location Jon_es 11 11,118 15:th-Jun-2017, 13:25:25
Last Post: Jon_es
  Remote Boot Opening sheppy1 15 16,882 6:th-Feb-2016, 13:34:46
Last Post: JohnL
  Secure My Car (Various Remote features including Remote Start) sheppy1 18 19,158 6:th-Feb-2016, 07:49:13
Last Post: mrtc
Users browsing this thread:
