remote issues
remote issues
hey guys
my remote has stopped working, it locks but not unlock.have changed the battery but no joy anyone had the same issue.
thanks
My Mrs Mokka is really temperamental with unlocking/locking.
You could try the negative off the battery for 60mins this will allow all systems to fully shut down & normally fixes alot of issues like this.
Thanks rusty will try
Hi rusty
tried the battery lead removal but made no difference, I have to assume it is a faulty key fob.
Have you tested it with the spare key?
hi rusty
spare key works fine
going to look into replacing the case first and if no joy the remote itself
well it was the remote case that was the issue it was an aftermarket one to begin with, got one from a scrapper damaged to use as an experiment and low and behold it works again. so i am going to have to find a better case now an original any thoughts?
Factory keys are sealed not to opened (but I'm sure it could be opened with care).
(18:th-Feb-2020, 19:30:40)Rusty2009 Wrote: Factory keys are sealed not to opened (but I'm sure it could be opened with care).
Thanks Rusty now sorted found an other factory key mint took time to undo and got it changed over works a treat
  Anyone remote SPS? milozic 1 3,299 12:th-Sep-2021, 15:31:26
  remote issues Qaranc 5 5,553 20:th-Oct-2020, 08:28:26
Question Blower issues Abc 9 9,769 14:th-Oct-2020, 13:29:13
  I bought a used GTC! - Fantastic car but a few issues i could do with advice about Mattymush 5 9,025 12:th-Jul-2020, 07:45:59
  Astra Issues – Faulty thermostat? dmort 1 7,109 15:th-Apr-2020, 12:30:52
  Astra J 2012 1.3cdti Starting Issues lordmpl 4 8,809 13:th-Jan-2019, 10:06:13
Last Post: lordmpl
  GTC Seatbelt issues Telsun 3 7,679 1:st-Jan-2019, 09:15:55
  2012 ASTRA J Central Locking Issues Matt Mcf 7 11,026 22:nd-Jan-2018, 14:05:19
  Fitted rear led lights, now bulb warning issues twinpipes 3 8,132 27:th-Jul-2017, 21:02:41
Last Post: Hummelshøj
