help urgent needed
Urgent help needed
Hi, replaced brakes on front of car and the stud on the hub snapped.
So there's 4 holding wheel on instead of five.
What's the best way to fix this?
Thanks guys
Isn't the stud part of the hub?
if so I would say a new hub is needed or a 2nd hand one.
Not sure, Google says your can replace them individually but knowing vx is have to change the whole hub. They expensive on a j do you know?
Found the info on TIS mate so hope it helps.
Wheel Stud Replacement
Removal Procedure
1.Raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle.
2.Remove the tyre and wheel assembly. Refer to Tyre and Wheel Removal and Installation.
3.Remove the wheel bearing/hub. Refer to Rear Wheel Bearing and Hub Replacement.
4.Release the wheel stud (1) from the bearing hub with the hydraulic press and DISCARD the stud.
Installation Procedure
1.Install a NEW stud into the bearing/hub assembly (2). Add enough washers (3) in order to draw the stud into the hub.
2.Install and tighten a wheel nut (1) until the head of the wheel stud is fully seated against the back of the bearing/hub flange (2).
3.Remove the wheel nut (1) and the washers (3).
4.Install the wheel bearing/hub (2). Refer to Rear Wheel Bearing and Hub Replacement .
5.Install the tyre and wheel assembly. Refer to Tyre and Wheel Removal and Installation .
6.Lower the vehicle.
Printable .PDF below for you.
http://vxoc.org.uk/Images/vxoc%20astra-j...cement.pdf
Brill thanks rusty
richje100 Wrote:Brill thanks rusty
No problems mate, you might be able to whack it out with a nice hefty lump hammer.
Fingers crossed.
Rusty, any idea of the size of the bolts? Found http://pages.ebay.com/link/?nav=item.vie...0541841245
I know mine is a STUD, M12, WHEEL TO HUB Part number 9599302 Autovaux charge £2.21 so I can't see it being much dearer from a dealer and they would get it in quicker.
Local dealer £2.57 each. Happy days.
SVS help needed again!!! hooper 6 7,532 20:th-Dec-2019, 13:57:40
  New Engine Needed ? Breengin 19 14,597 14:th-Mar-2019, 08:48:57
  A little knowledge needed please Sri~mike 4 6,291 11:th-Mar-2019, 01:33:41
Last Post: Sri~mike
  coolant tank hose ref needed alexy357 1 4,447 4:th-Mar-2019, 08:43:32
  URGENT HELP NEEDED!!!! Michael T18 7 7,554 17:th-Sep-2018, 14:07:50
Last Post: Michael T18
  Alternator part code needed for astra gtc j 2014 cdti 2.0 king 4 8,386 20:th-Apr-2018, 09:01:30
Last Post: king
  Part numbers needed Daniel199025 5 7,420 15:th-Sep-2017, 13:48:20
Last Post: Daniel199025
  GTC body kit, color advice needed twinpipes 3 7,678 5:th-Aug-2017, 12:03:36
Last Post: gregj
Little help needed Jon3sy 8 9,322 29:th-Jun-2017, 07:37:54
  Knowledge about my grill needed DE5IRED 3 7,691 19:th-Mar-2015, 18:40:22
