needed numbers part
Part numbers needed
Hi guys I need some help with part numbers for a little project am going to be completing. If possible does anybody know the numbers to order a new lower grill for a 2012 Astra gtc and also the part number for the vx line rear bumper that's on the gtc limited edition models thanks in advance
I'll have a look later for you.
think you need
lower grille
13342492 exc front park assist
13347325 front park assist
both non vxr line or bi turbo
B12 | REAR BUMPER // 3 DOOR HATCH 08 (EXCEPT OPC, VXR)
1 13352446 14 04 370 1 BUMPER, REAR (EXCEPT ADVANCED PARKING ASSISTANT) EXCEPT BITURBO, EXC.OPC LINE / VXR STYLING PACK 1 & 2, EXCEPT OPEL MOTORSPORT EDITION PACK
1 13411896 14 04 667 1 BUMPER, REAR (FOR ADVANCED PARKING ASSISTANT, RPO UDP) EXCEPT BITURBO, EXC.OPC LINE / VXR STYLING PACK 1 & 2, EXCEPT OPEL MOTORSPORT EDITION PACK
1 13352446 14 04 370 1 BUMPER, REAR (EXCEPT PARKING PILOT SYSTEM) BITURBO, OPC LINE / VXR STYLING PACK 1 & 2, RPO WMT / WBP, OPEL MOTORSPORT EDITION PACK, RPO WKX
1 13409684 14 04 585 1 BUMPER, REAR (FOR PARKING PILOT SYSTEM, RPO UD5 / UD7) BITURBO, OPC LINE / VXR STYLING PACK 1 & 2, RPO WMT / WBP, OPEL MOTORSPORT EDITION PACK, RPO WKX
2 13342514 14 04 380 1 INSERT, REAR BUMPER, ANTHRACITE, GRAINED (EXCEPT PARKING PILOT SYSTEM) EXCEPT BITURBO, EXC.OPC LINE / VXR STYLING PACK 1 & 2, EXCEPT OPEL MOTORSPORT EDITION PACK
3 13345821 14 04 381 1 INSERT, REAR BUMPER, ANTHRACITE, GRAINED (FOR PARKING PILOT SYSTEM)
IF REQUIRED CUT HOLES FOR VISIBLE EXHAUST OR TRAILER COUPLING
4 13345828 14 05 122 1 FLAP, TOWING LUG, ANTHRACITE, GRAINED EXCEPT BITURBO, EXC.OPC LINE / VXR STYLING PACK 1 & 2, EXCEPT OPEL MOTORSPORT EDITION PACK
5 13281260 14 56 004 1 REFLECTOR, REAR BUMPER PANEL, RH EXCEPT BITURBO, EXC.OPC LINE / VXR STYLING PACK 1 & 2, EXCEPT OPEL MOTORSPORT EDITION PACK
5 13281259 14 56 003 1 REFLECTOR, REAR BUMPER PANEL, LH EXCEPT BITURBO, EXC.OPC LINE / VXR STYLING PACK 1 & 2, EXCEPT OPEL MOTORSPORT EDITION PACK
6 13346636 14 04 499 1 EXTENSION, REAR BUMPER PANEL, PRIMED (LESS VISIBLE CHROME EXHAUST TAIL PIPE) OPC LINE / VXR STYLING PACK 1 & 2, RPO WMT / WBP, OPEL MOTORSPORT EDITION PACK, RPO WKX
7 13346637 14 04 501 1 EXTENSION, REAR BUMPER PANEL, PRIMED (FOR VISIBLE CHROME EXHAUST TAIL PIPE) OPC LINE / VXR STYLING PACK 1 & 2, RPO WMT / WBP, OPEL MOTORSPORT EDITION PACK, RPO WKX, A14NEL[LUJ], B14NEL[LUJ], A14NET[LUJ], B14NET[LUJ], A16LET[LLU], A16XHT[LVP], A20DTH[LBS], Y20DTJ[LBX], Z20DTJ[LBX]
7 13346640 14 04 503 1 EXTENSION, REAR BUMPER PANEL, PRIMED (FOR VISIBLE CHROME EXHAUST TAIL PIPE) OPC LINE / VXR STYLING PACK 1 & 2, RPO WMT / WBP, OPEL MOTORSPORT EDITION PACK, RPO WKX, A16SHT[LWC], B16SHT[LWC]
7 13346637 14 04 501 1 EXTENSION, REAR BUMPER PANEL, PRIMED (FOR VISIBLE CHROME EXHAUST TAIL PIPE) OPC LINE / VXR STYLING PACK 1 & 2, RPO WMT / WBP, OPEL MOTORSPORT EDITION PACK, RPO WKX, B16SHL[LWC
if they are not what you want let me know and I will look further for you
Wow that list is confusing thought it be simpler lol. It's the bumper that's on the new limited edition gtc with the black kinda line on it as opposed to the larger black diffuser that was on the earlier models.
Also will those grills fit the gtc just need the standard lower grill without parking sensors etc
Ideally this one on eBay
Item number is 272805149061
The part number on there doesn't seem to work when searching for one?
(15:th-Sep-2017, 11:40:46)Daniel199025 Wrote: Wow that list is confusing thought it be simpler lol. It's the bumper that's on the new limited edition gtc with the black kinda line on it as opposed to the larger black diffuser that was on the earlier models.
the grilles are for 3 door yes, the bumper if you see a reg number with one on I can look up the correct bumper for you
http://www.autotrader.co.uk/classified/a...ial&page=1
13378297 14 04 502 1 INSERT BITURBO, OPC LINE / VXR STYLING PACK 1 & 2, RPO WMT / WBP, OPEL MOTORSPORT EDITION PACK, RPO WKX
9 13377894 14 05 149 1 FLAP, TOWING LUG BITURBO, OPC LINE / VXR STYLING PACK 1 & 2, RPO WMT / WBP, OPEL MOTORSPORT EDITION PACK, RPO WKX
10 13365620 14 56 006 1 REFLECTOR, REAR BUMPER PANEL, RH BITURBO, OPC LINE / VXR STYLING PACK 1 & 2, RPO WMT / WBP, OPEL MOTORSPORT EDITION PACK, RPO WKX
10 13365619 14 56 005 1 REFLECTOR, REAR BUMPER PANEL, LH BITURBO, OPC LINE / VXR STYLING PACK 1 & 2, RPO WMT / WBP, OPEL MOTORSPORT EDITION PACK, RPO WKX
11 90087290 11 04 880 2 RIVET, EXPANDING, EXTENSION FIXING BITURBO, OPC LINE / VXR STYLING PACK 1 & 2, RPO WMT / WBP, OPEL MOTORSPORT EDITION PACK, RPO WKX
there you go
Hi yeah that's the bumper shown on the yellow gtc advert that's the one I'm looking for thanks
  Inlet air pipe gasket part number. Euroshopper 1 4,165 31:st-Dec-2020, 17:23:19
SVS help needed again!!! hooper 6 7,929 20:th-Dec-2019, 13:57:40
  New Engine Needed ? Breengin 19 15,624 14:th-Mar-2019, 08:48:57
  A little knowledge needed please Sri~mike 4 6,670 11:th-Mar-2019, 01:33:41
Last Post: Sri~mike
  coolant tank hose ref needed alexy357 1 4,649 4:th-Mar-2019, 08:43:32
  URGENT HELP NEEDED!!!! Michael T18 7 7,939 17:th-Sep-2018, 14:07:50
Last Post: Michael T18
  Alternator part code needed for astra gtc j 2014 cdti 2.0 king 4 8,813 20:th-Apr-2018, 09:01:30
Last Post: king
  Has anyone got this part?? 13349320 Amazingusername 11 12,201 30:th-Mar-2018, 18:05:46
Last Post: Amazingusername
  GTC body kit, color advice needed twinpipes 3 8,021 5:th-Aug-2017, 12:03:36
Last Post: gregj
Little help needed Jon3sy 8 9,861 29:th-Jun-2017, 07:37:54
