Urgent help needed
Hi, replaced brakes on front of car and the stud on the hub snapped.
So there's 4 holding wheel on instead of five.
What's the best way to fix this?
Thanks guys
URGENT HELP PLEASE: Distressed Engine Squeel/Groan
Hi folks,
Im after some desperate urgent help please.
Our Astra J 2.0 CDTI 2011, has today developed, what I can only describe as, a distressed squeel/groan from the right hand side of the engine.
It sounds like its coming from around the alternator/cambelt area.
In addition, im also hearing a faint distant metallic rattle.
Can you please help?
Its intermittent but in the last few hours and after about a 10 mile drive its gradually gotten slightly louder and more frequent.
URGENT HELP - UNDERTRAY back on
Hey guys need some real help.
I have a 1.7 diesel Astra 62 plate.
I have undone the undertray part where it allows u to merely pull down a flap to get to the engine oil sump. I am now trying to fix the screw back in but they just keep falling back out.
So even when there in the slightest tap makes them Unscrew which not safe for road. Has anyone had this problem. I'll attach pics of the screws.
PLEASE HELP AS WORRY I'M GNA BE HERE ALL NIGHT.[IMG]https://uploads.tapatalk-cdn.com/20180107/fc
URGENT HELP PLEASE - What is the pipe / oil leak
Hey guys
I have a astra J 62 1.7 diesel.
I noticed today a suction / hiss noise. Looked in my engine and saw duct tape wrapped around a pipe and could feel air escaping, this was obvs put there to try patch it and then there was oil residue over it / over my radiator fan / surrounding arwas as if it's be spraying it out.
(Will attach video links)
Video 1:The duct tape over pipe
https://youtu.be/_0Ciw7VBhrs
1) Could someone please tell me what this pipe is / does?
2) Is the oil residue and
URGENT HELP NEEDED!!!!
Hi people I have bought an air induction pipe from eBay brand: DNA this is going to be a stupid question but I’m stuck on how to fit it iv been out and tryes but I don’t feel it fits correctly, and it also has a valve piece on it which I don’t know what for ??
TIA
[Image: https://uploads.tapatalk-cdn.com/2018091...ea19b4.png]
Urgent help required.
[align=center]Hi guys need advice. I have a gtc 2.0 diesel. Car was serviced a couple of weeks ago and got timing belt done too. Car has done 70000 miles and is a 2012. Anyway to cut a long story short, when I left garage warning came up service car soon, rang garage they said turn car off and start again and message should go away, which it did. Driving home from work today service car soon came on again and car immediately stalled. Nursed the car home but I had to go out again., service car so
Newbie Urgent Wiper Washer Fault help
Firstly hi Everyone
new to this forum so hopeful be able to get some help form you guys as heard some good things...
I have a 2014 Astra J 1.7 Diesel that's just failed its MOT due to wipers not providing water.
both front and back decided to stop so did the usual, blew some air through the pipes and cleaned the nozzles and washer bottle out
wasn't getting a hum from the motor when the stalk was pulled forward or backwards so purchased a new washer pump which solved the rear issue bu
