gauge two? or one
One Gauge Or Two?
Really considering a boost gauge and putting it into a pod on the A pillar. Should I just go for one gauge or two but if two what other to go in pod with boost?
What about oil pressure?
Actually I didnt think about oil pressure. Cheers mate ill have a look, I was think of a volts gauge.
You can get the voltage on dash.
Mate sounds stupid but didnt even know that.
Before
[Image: Standard.jpg]
After
[Image: Moded.jpg]
Before
[Image: Stanard%202.jpg]
After
[Image: mod%20full.jpg]
Quote:Trip computer 10 min job to activate. They have to SPS the dials on "configuration and setup" set all to default to save time looking up the RPO codes then look for "driver information center" then change it to "yes" this will originally be set to "no" when "SET TO DEFAULT" has been entered.
On the later cars the sensor for both the header tank and washer bottle are missing and will bring CODE 3 and 174. If you make a bridge for the two pins on the plug the codes will go away. Unless you want to fit a new header tank and washer bottle with the sensors in.
Cheers mate I will have a look at this.
  Boost Gauge Andy1874 4 6,817 25:th-Jul-2020, 17:56:32
Last Post: Nubby
  Temperature gauge Pg1710 1 4,524 10:th-Apr-2018, 07:51:14
  Temp gauge kippax 11 16,589 11:th-Jan-2017, 09:55:26
Last Post: kippax
  Fuel Gauge Indicator Farrael 7 10,220 10:th-Aug-2016, 10:01:31
Last Post: bhalay207
