remove badge rear
Remove rear badge
Thinking of getting the rear badge hydrodipped a mix of red and black, can you remove it to dip it??
yes you can remove it the same way as the rear badges but the are two lugs at the bottom so dont break them
but you would have to use new 3m sticky tape to put it back on
tucpal Wrote:yes you can remove it the same way as the rear badges but the are two lugs at the bottom so dont break them
Thanks, I'm wanting it in a red and black like the video below, might get the engine cover done as well
[video=youtube_share;rmSV2l6JFt0]http://youtu.be/rmSV2l6JFt0[/video]
  Lowering springs identify front rear martinpe68 1 3,761 12:th-Sep-2021, 15:22:37
  Astra J Rear Bench Seat Clip. MrScottyMan 1 6,647 24:th-Jan-2021, 14:44:22
  Rear diffuser Elad1962 3 4,778 29:th-Sep-2020, 22:14:18
  BiTurbo Rear Bumper Dudderz 3 6,421 5:th-Jun-2020, 19:49:44
  Rear Bumper PN 13346637 Jonnymac07 1 3,693 13:th-May-2020, 14:56:05
Last Post: paula9568
  Blank/Remove EGR sheppy1 17 20,081 9:th-Jul-2019, 10:47:03
Last Post: Youngy93
  Rear brake pads and discs everson38 4 6,394 28:th-May-2019, 10:53:57
  electric rear windows marky79 5 6,855 11:th-Jan-2019, 09:04:32
  Rear Light Replacement (Need Advice) A.ROD 2 7,121 17:th-Dec-2018, 19:17:48
Last Post: A.ROD
  GTC water collects under rear window Canasta 2 6,805 30:th-Oct-2018, 22:23:04
Last Post: marky79
