diesel battery new reg j 2013 7 astra 1 for
New Battery for Astra J 2013 reg 1.7 diesel
I bought a 13 reg Astra J  1.7 diesel 3 years ago & I need a new battery..
Is it a straight swap in & out or are there any nuances I need to know before I change? Alarm/door lock/anti theft etc etc
I dont know if my car has a stop start system because it never worked but would not surprise me if it had it?
Is there any way of know whether a car has stop/start system or not
cheers
Battery should be straight in straight out.
Mine was,
Should say auto stop I believe on the rev counter
(16:th-Nov-2020, 21:22:49)Jpbroad1970 Wrote: Battery should be straight in straight out.
Mine was,
Thanks for info....
No codes etc required you will have to reset the time and favourite's etc on the radio.
Make sure car is unlocked when changing the battery.
As John said if you have stop/start you will have auto stop on the rev side of the cluster, you will also have an eco button on the dash.
I can reccomend Varta for S/S systems. I have been using one 3 years nie and so far it is trouble free.
I had the battery go on my Cascada 2.0 cdti recently so went to Halfords as they were less than half the price of Eurocarparts even after discount complete with a 5 year warrantee. I'm glad I got them to fit it as a few things had to be removed to get the battery out!
I didn't have to reset anything, even the radio stations etc were saved.
(12:th-May-2021, 14:57:02)MarkAP68 Wrote: I didn't have to reset anything, even the radio stations etc were saved.
There should have been a message popped up on the odometer display giving details of how to reset the one touch windows, which do require resetting after a power interruption.
  VAUXHALL ASTRA 1.7 CDTI FUEL SENDER UNIT 13272601- FUEL ERRATIC GUAGE BELWO HALF TAN caretaker 3 3,651 21:st-Oct-2024, 18:22:15
  Threaded Mode Diesel Fuel guage erratic low fuel and then half tank caretaker 1 4,435 30:th-Dec-2022, 17:32:20
  Astra 1.6 CDTi Turbo Issues P2598 shaky411 1 6,869 12:th-Sep-2021, 15:24:05
  Vxr bumper on 5 door Astra j Sh4rk2007 10 13,676 6:th-Jun-2021, 18:25:04
Last Post: jeniferbitcoin71
  Diesel door wont opel Arkanggel10 2 3,637 13:th-May-2021, 15:31:33
Last Post: Arkanggel10
  Astra J 1.4T Exhaust help sammpennington 1 6,419 12:th-May-2021, 14:29:50
Last Post: azajus
  Astra j gtc modifications BillyBryan 2 4,871 9:th-May-2021, 17:15:36
Last Post: Spaghetti
  Timing belt for 1.7 2013 rodduz 3 4,934 14:th-Mar-2021, 13:07:22
  Astra J Fault code reader suggestions Euroshopper 1 4,803 22:nd-Feb-2021, 08:50:12
  Astra j bonnet won't open help Paul in sheppy 2 4,794 17:th-Feb-2021, 13:13:46
Last Post: Paul in sheppy
Requan (8:th-Aug-2025, 14:11:54)
