baffling new light leaks coming no coolant is sensor me and when full on
Coolant light coming on when coolant is full (new sensor and no leaks) baffling me!
Hi everyone,
So randomly a couple of weeks ago I got "coolant level low" light on. So I topped it up a little. It came on again so I added a little more to the point that it's on or over where it should be. The error keeps popping up but it will disappear after 10-20 seconds.
I've checked and there are no leaks and the coolant isn't going down at all. I've replaced the coolant sensor too and the message still pops up.
The car never gets hotter than the 90 mark and doesn't smell hot either so it's baffling me. Anyone had this issue?
It's an Astra J 2.0 CDTI 2013 165ps.
All I see is a blank message. Are you typing in a certain font colour, or has your screen ink run out?
Sorry not sure what happened there, the message was:
Hi everyone,
Think they are prone to header tanks , the float inside the tank breaks down.
  Clean DPF - O2 sensor location Henhead78 1 150 24:th-Apr-2026, 17:31:05
  Retrofit Coolant and Wiper Fluid Sensors sheppy1 13 15,696 2:nd-May-2025, 17:32:02
Last Post: dellpiron
  Brake pedal sensor learn. Richiew1986 0 3,019 22:nd-Jul-2021, 16:53:31
Last Post: Richiew1986
  coolant pressure tester chuzzle359 0 3,402 14:th-Apr-2021, 18:23:08
Last Post: chuzzle359
  parking sensor Qaranc 1 3,888 8:th-Feb-2021, 01:33:43
Last Post: loeb
  Glowplugs with pressure sensor or not Euroshopper 3 5,745 2:nd-Nov-2020, 16:01:21
  Gtc 2017 1.4t 120 coolant leak Nathan191210 1 5,632 1:st-Oct-2020, 07:02:07
  DPF REGEN LIGHT Starie 113 148,375 19:th-Apr-2020, 21:00:20
Last Post: Multiskilled
Shocked Spanner Light illuminated with engine off Wwood1991 2 5,970 11:th-Feb-2020, 13:01:57
  DPF pressure sensor richardhmorgan1 3 7,028 24:th-Sep-2019, 20:08:31
Last Post: Saunter
