to nav500 cd400 upgrade
Cd400 to nav500 upgrade.
hi there! I'm new on this forum, living in the Netherlands and searching for info for replacing my CD400 system for a
NAVI600 system. My Astra J Sports Tourer already has the bluetooth module; Besides this it only has the AUX
input for 3.5mm audio plugs. I already have the complete NAVI600 system (UCU unit, display unit, control unit,
USB - SD card module - see pictures). The UCU unit is already unlocked so it should be accepted after installation.
Problem which I have now are:
1 - not having GVIF cable which is the video cable which connects the display to the UCU unit (blue connectors)
2 - not having the USB cable to connect USB module to UCU unit
3 - not having cable to connect SC card / 3.5 input jack to UCU unit
Could somebody tell me where I can get these cables?? Other question I have is about wiring: the guy who
unlocked my UCU control unit told me that I have to make some small changes in the wiring system; does
anyone knows if thats correct and if yes could you tell me what I need to change in the wiring?? Hope one of
you can help me out with these questions; really appriciated!!
BR Bas
Hi guys, I have a 2011 Elite with a basic CD400 in it.
What would be needed to upgrade to have a satnav?
I've seen 500, 600, 650 & 950 kits advertised but I'm not sure if they would be compatible.
(2:nd-Jan-2021, 22:08:52)woutfab Wrote: hi there! I'm new on this forum, living in the Netherlands and searching for info for replacing my CD400 system for a
BR Bas
The GVIF cable is part number 95353437
The USB connect into the SD port mini-b to mini-b link
SD to Radio Mini-A to Mini-B
Yes there are wiring changes needed.
(6:th-Jan-2021, 23:26:21)THEHITMAN Wrote: Hi guys, I have a 2011 Elite with a basic CD400 in it.
As to what is needed depends on the navi unit yo go for.
500/650/950, Screen + surround, main unit, control panel, USB tray and port
600/900 Screen + surround, main unit, control panel, Tray for SD port USB/AUX port plus the ports.
Wiring changes GPS aerial, then it needs programming.
BR Bas
So what's the easiest changeover then, NAV500?
Does the 500 need the aerial as well and need programmed?
Yes cd500 is the earliest & yes to a GPS aerial wiring changing and programming.
These are what I use unless custom wants to add a roof aerial on. https://www.ebay.co.uk/itm/GPS-SAT-NAV-A...SwqLlcRW0m
(10:th-Jan-2021, 08:16:04)Rusty2009 Wrote: Yes cd500 is the earliest & yes to a GPS aerial wiring changing and programming.
Is it easier to change to an aftermarket sat nav unit like this one https://www.ebay.co.uk/itm/8-ANDROID-10-...SweThfJFcD
I want to keep the cd player lol
BR Bas
Thx Rusty for explaining which cables I need! One question left: at the back of the USB-AUX-SD Card console there are two pins next to the connector for USB cable which goes to radio unit. Do you know where those pins are needed for; do I need to connect something on these pins ore will SD card work when USB cable between console and radio is connected?
BR Bas
I think the one you are talking about it the power supply, this is needed for the sd card side of things to work.
(12:th-Jan-2021, 08:02:24)Jpbroad1970 Wrote: I think the one you are talking about it the power supply, this is needed for the sd card side of things to work.
Hi JP,
thanks for reply. Guess you are wright and connections are needed for 12v power supply. Any idea how to find out
which pin is for +12v and which one is for ground??
BR Bas
Black is ground, the other is red and yellow which is power.
Think I have a photo somewhere
Pin 1 is black
Pin 2 is red/yellow
Sent from my SM-G780F using Tapatalk
(13:th-Jan-2021, 19:07:55)Jpbroad1970 Wrote: Black is ground, the other is red and yellow which is power.
Pin 1 is black
Pin 2 is red/yellow
Thx JP; done; succesfully swapped CD400 to NAVI600 in my Astra J!! Took me some time but it works Wink...
BR Bas
An interesting thread. Looking to improve my Astra J 2011 Elite with a CD400 fitted. I can't find the DAB cable, which is a shame. If I add DAB, then options will be to either make something or just get a custom cable from Rusty2009 (I've not seen anyone else sell them). Do the various wires from that DAB cable have to be crimped/pushed into appropriate slots on the 38 way (I think) main connector on the back of the radio?
I might also try and fit an Ebay Navi 500/600 etc, and would expect to have to post the unit away to be coded to the vehicle (and allow DAB+)
I've currently got a dashboard stick-on DAB+/Bluetooth radio that streams music. I've read that all but the high-end Navi radios can't stream music, so whatever I replace the CD400 with I may still end up using that stick-on thing for Bluetooth streaming.
An easy solution for a first dabble into this might just be to get the DAB+ module (has to be DAB+) and use that with the CD400.
As no-one who posts here lives nearby (Kent) whatever I do I might just have to do myself, with info/cables/coding by post. Hard to know what it's worth doing on a 10 year-old car. It's low mileage, so I'll probably keep the car a few years. A shame Vauxhall weren't putting DAB into cars by 2011. I'm sure the 2011 Fords I looked at had DAB.
Hi there, im new here with many doubts. Is it possible to use CD500 display unit on a CD400 anyhow?
(4:th-May-2014, 10:25:51)vxmods Wrote: ive not got the navi600 setup,its the aditional parts that i
  have to go with a setup
   ive already proved it can be retro fitted in tucpals
    astra.
     Big grin
can u do a navi 600 supplied and fitted for a vauxhall insignia on 13 plate please
Rusty is your man he is fantastic SmileYeah
Rusty is your man to fix the radio/cd problems he is excellent and a nice day out in Bournemouth too.
Rusty is your man to fix the radio/cd problems he is excellent and a nice day out in BournemouthHi just picked up a 2012 GTC would like to add bluetooth to the CD400 it hs dab and the aux/usb too what pricehelp is available for this i assume as thet are a good price on ebay i could buy the CD500 as i kit and if someone couls fit and program it that would be good i am based in cardiff but dont mind drivingThanks
Cd500 nice and easy if you have all the bits, screen wire is hardest to come by. If you aren't bothered about nav I would say either cd400 all in one which has dab and Bluetooth built in or cd600 if you want colour screen.
  Stereo upgrade options Amazingusername 6 13,899 9:th-Feb-2021, 14:07:41
Last Post: loeb
  Upgrading the CD400 sadiqr10 0 5,189 11:th-Nov-2020, 04:58:09
Last Post: sadiqr10
  Cd400 software update Lukedent1234 8 14,507 21:st-Sep-2019, 10:00:32
  cd400 quality rbull51 9 18,297 24:th-Aug-2019, 18:02:12
  Wanting to install bluetooth and upgrade CD400 andy2174 14 36,253 1:st-Mar-2018, 20:27:35
  HID upgrade Dale90 29 24,978 10:th-Aug-2017, 09:33:25
Last Post: Dale90
  CD400 reception problem MDS2017 3 11,155 3:rd-Mar-2017, 21:00:27
Last Post: GOKIWI
  ECM "Upgrade" Recall Causing Performance Issue? Black_Cat 4 9,547 6:th-Nov-2016, 22:57:55
  Shark fin for cd400 chrisb2511 10 35,968 10:th-Aug-2016, 07:21:51
  Washer jet upgrade / change? rbull51 1 6,432 27:th-Jul-2016, 22:58:36
7 User(s) read this thread:
jas7c5-2008 (4:th-Jan-2026, 16:42:35), orhunnx (19:th-Feb-2025, 03:35:35), ukimpact2009 (11:th-May-2025, 20:11:58), TomBonk (29:th-May-2025, 12:13:33), Rustic302 (1:st-Sep-2025, 14:08:24), Feigenbaum (5:th-Sep-2025, 08:45:12), tanarchy (3:rd-Oct-2025, 15:12:34)
