connector navi600 usb
Navi600 usb connector
Does anybody know the size of the usb connection that plugs into the back of the radio headunit
Lindy cable 31632 will go from sd port to navi
Thank you , do you know if I’m able to buy an adapter to take it up to standard usb connector , as I want to be able to use existing usb centre console connection with my aftermarket pioneer radio , so I don’t have to run extra cabling or fit a new flush mounted USB adapter
If you were to of asked that in your original question it would of been easier.
There is no adaptor that can fit the factory USB plug on the radio end.
I'm assuming your keeping the SD port, USB & AUX port.
If so you will want a Type A to Mini-B
https://www.lindy.co.uk/cables-adapters-...ine-p11324
  Driver door connector pinout Mara_J 5 9,749 14:th-Nov-2020, 09:53:25
  Retrofitting Navi650 from Navi600 dantheman 0 5,434 20:th-Aug-2019, 14:16:16
Last Post: dantheman
  Airbag connector BishopSRB 5 8,453 26:th-Jan-2019, 22:37:33
Last Post: BishopSRB
  ECO button connector diagram (start/stop) aurega 1 11,187 4:th-Nov-2018, 15:06:37
  cd400 vs navi600 niteram 7 10,799 27:th-Aug-2018, 09:02:10
jas7c5-2008 (4:th-Jan-2026, 17:47:11)
