scv injectors problem? or
Injectors or SCV problem?
I have a problem with my 1.7 in the morning. I can feel it vibrate a bit to strong when the engine is cold. Everything is back to normal after 4 minutes. I haave read the injectors values and they are jumping around for 4 minutes until injectors will stabilize. Any in here that can read these values and tell me if the injectors are running properly?
(2:nd-Mar-2020, 21:56:04)kartush45 Wrote: I have a problem with my 1.7 in the morning. I can feel it vibrate a bit to strong when the engine is cold. Everything is back to normal after 4 minutes. I haave read the injectors values and they are jumping around for 4 minutes until injectors will stabilize. Any in here that can read these values and tell me if the injectors are running properly?
IIRC the 1.7 is prone to SCV issues which causes it.
Sad Astra 1.7 CDTI fuel quality problem klajdi 0 3,820 10:th-Sep-2020, 12:10:05
Last Post: klajdi
  Electric Window intermittent problem Stanhope 3 6,911 21:st-Mar-2019, 14:35:49
Last Post: Stanhope
  Astra J self starting problem Jopo2311 8 7,826 16:th-Mar-2019, 10:29:33
  Help-2012 Astra J S model rear window demister button problem irishastraowner 14 18,069 26:th-Sep-2018, 23:50:59
Last Post: everson38
  Can't get in gear - clutch problem? klargon 0 4,824 9:th-Dec-2017, 16:21:11
Last Post: klargon
  Problem with DRL mw2299 5 6,788 21:st-Sep-2017, 07:25:38
Last Post: andiman t
  Intermittend starting problem eliasvdv 2 6,737 18:th-Jun-2017, 10:48:13
Last Post: eliasvdv
  Astra J Infinity Sound problem abba34 9 11,409 11:th-Mar-2017, 17:59:21
Last Post: abba34
  CD400 reception problem MDS2017 3 11,087 3:rd-Mar-2017, 21:00:27
Last Post: GOKIWI
  Astra Gtc 1.4t clutch problem Wayneofwolves 2 6,311 25:th-Feb-2017, 09:16:33
Last Post: Wayneofwolves
