to in 400 62 plate options astra replace navi
Options to replace Navi 400 in 62 plate Astra
Hi there
I've recently bought a second hand 62 plate sri turbo, and loving the car overall. Was buying second hand so didn't have a huge amount of choice in relation to optional extras etc!
However, I've got the basic navi 400 without bluetooth connectivity. It's all a bit too basic, and I'm planning to keep this car for a few years, so looking at options to replace the infotainment system.
I'm hoping someone might be able to let me know what is available in terms of other vauxhall/opel units that would be a straight swap (and possibly the process of replacing, and connecting new unit to wheel controls for example). I've heard there are also aftermarket options out there (including some that potentially work with carplay etc!?), and would also be interested to see if anyone has any experience of them too?
I understand that there are some android units on the market too. However, the easier the install the better as I'm going to look at doing it myself!
Thanks in advance, grateful if anyone is able to help!
Atarius
Hi and welcome.
The best option if you want to go factory look is a navi950 system, not the cheapest but the best look.
Android units I'm not up to speed with.
If changing to a 950 there are wiring modifications and programming to do.
As John said there is the navi950 best out of all the factory satnav's.
Android units I'm not a fan of BT is rubbish on them.
Double din is the other option.
I'm selling a full Double din set-up https://www.vxoc.org.uk/forum/Thread-Double-din-setup
(11:th-Sep-2018, 07:31:10)Jpbroad1970 Wrote: Hi and welcome.
(11:th-Sep-2018, 07:42:26)Rusty2009 Wrote: As John said there is the navi950 best out of all the factory satnav's.
Cheers both, that's helpful. JPBroad, do you know if there are any tutorials out there to get me started? (is this something that someone can do at home, assuming I have the time and tools!?)
Rusty, any resources out there that you'd point me to in relation to double din units and how to install them?
In terms of Navi retrofitting there are no guides on how to do it, John or myself can fit them.
As for fitting double din I did a how-to
https://www.vxoc.org.uk/forum/Thread-How...-head-unit
I've also just read through some of your tutorials and they look like a really good starting point, brilliant stuff. I've only found them by searching around, any chance you can point me through to the most up to date tutorials (if they've changed since the ones I found below).
Whilst looking at double din units is there anything I need to look out for to make sure it's compatible, will work with the steering wheel controls (connect 2 unit by the looks of it) etc.?
https://www.vxoc.org.uk/forum/Thread-How...en-removal
Personally I only go for factory fit options as in my opinion they look the best and integrate the best as they are designed to fit the best. But it's personal choice really and it's why forums like this work as there are plenty of people to offer all sorts of opinions.
How-to's are up-to date, if they are ever updated the main how-to is updated.
Yes a connects2 fitting kit is needed with a patch lead for the brand of radio you buy and it will work with steering controls.
What I'm selling is a complete kit Radio, DAB, TV, Rear screens (great if you have kids and do long journeys), speakers & connects2 fitting kit.
  Astra J Instrument Cluster 32pin wiring diagram Milo629 3 9,934 2:nd-May-2025, 12:12:20
Last Post: dellpiron
  cd 400 upgrade to navi 600 need help goose9029 6 9,270 14:th-Feb-2024, 07:52:16
  TPMS on Astra J GTC milozic 0 3,311 14:th-May-2023, 18:58:09
Last Post: milozic
  insignia cluster into astra? Tylerrattv 48 63,350 30:th-Jul-2021, 18:27:37
Last Post: theendfear
  vin relearn navi 600 geoffp 1 3,629 5:th-Jul-2021, 15:38:22
Last Post: livo
  Navi 650 bluetooth and reverse camera mislav_os 30 35,033 9:th-Jun-2021, 16:08:07
  Navi 950 retrofit to Buick Encore vibalt 3 13,022 21:st-Jul-2020, 19:02:30
  navi 500 programming tzr608 14 21,092 15:th-Mar-2020, 23:15:54
  Rear camera fit on Opel astra sports tourer info ;) Alienbv 24 28,907 26:th-Dec-2019, 13:00:29
  astra k cluster on astra j Maniacu 2 9,625 6:th-Jun-2019, 14:37:10
Last Post: Maniacu
luks104 (26:th-Feb-2025, 18:47:17), jas7c5-2008 (30:th-Dec-2025, 16:35:05)
