to ??? wiring cd400 cd500
cd400 to cd500 wiring ???
Hi everyone can someone on here give me the wiring diagram for changing my astra gtc 2013 cd400 to a cd500(navi 500)
want to upgrade my radio but need help thanks
I don't think anyone will share that info. Some of us have worked very hard working it all out. You also if you didn't know need to be able to program it.
(15:th-Jul-2018, 08:27:41)Jpbroad1970 Wrote: I don't think anyone will share that info. Some of us have worked very hard working it all out. You also if you didn't know need to be able to program it.
so i had a go at fitting ....got the radio / satnav working but radio ariel not good and non of the stearing wheel controls work....is this because of programming????
Did you do the rewiring?
Poor signal/controls shouldn't be down to programming.
Do the dash controls work OK?
(15:th-Jul-2018, 19:44:48)Jpbroad1970 Wrote: Did you do the rewiring?
i bought a harness lead for a parrot and worked out the changes .... did the rewiring and unit works ...all buttons work ....but the only things that dont work are the temp on the screen  and the controls on the steering wheel. I did buy and fit a gps fin that connected to the plug on the roof but turned out that there wasnt any plug around the radio dash to plug in so dont know where that is ....but also had a fakra gps so plugged that in and works fine .so really i just wanted the radio signal (i have dab on my cd400)and steering controls working and then i can fit......i put my cd400 back in til i can sort out what doesnt work.....also i have the bluetooth module that i want to retrofit but dont know what wires go where as i dont have any connector or wiring for that yet....any help would be great...thanks
I take it your dab signal is bad also.
I had that on my old elite.
One off the changes you make shuts off power
To the aerial amplifiers.
(16:th-Jul-2018, 20:49:23)Jpbroad1970 Wrote: I take it your dab signal is bad also.
tbh the signal on the cd400  was rubbish but i get nothing when i fitted the cd500 in the car...when i bench tested with a old ariel it was fine on fm but really wanted dab on the new cd500   ....is the dab i have able to work on the cd500 or do i need to do something else ???? and how would i put power back to the dab??? thanks mal
Like I say I had same when I fitted 950 the fm and dab have powered amps and when you change one of the wires it cuts power to them amps. I can't remember pin. To add dab officially you would need vci to add dab.
(16:th-Jul-2018, 21:37:55)Jpbroad1970 Wrote: Like I say I had same when I fitted 950 the fm and dab have powered amps and when you change one of the wires it cuts power to them amps. I can't remember pin. To add dab officially you would need vci to add dab.
if you remember the pin that would put power back to the amps i would be very happy thanks Jpbroad1970
Pin 43 is the remote signal wire which supply's power to said aerials.
(14:th-Jul-2018, 19:06:11)tzr608 Wrote: Hi everyone can someone on here give me the wiring diagram for changing my astra gtc 2013 cd400 to a cd500(navi 500)
hi. i am just new here. and try to upgrade my CD400 to CD500 Navi in insignia. But my first problem that the original connector to center control console have only 4 wire but the new one for CD500 have connector with 8 wires ??
can any one please advise how to rewire the CD500
thanks
Polish lang
.pdf   Schemat navi Astra J.pdf (Size: 734.36 KB / Downloads: 212)
(17:th-Dec-2018, 14:38:23)BOLT Wrote: Polish lang
Thanks man you the best  Thumbs
byway do you know witch wire on the radio for revers switch. i try to fit revers camera .
can you help please
  Request heated steering wheel wiring diagram emilalexandrubarb 2 3,211 19:th-Dec-2024, 20:16:39
Last Post: emilalexandrubarb
  Speaker wiring info Rusty2009 1 10,339 20:th-Feb-2023, 14:40:24
Last Post: Valentin
  cd500 to navi950 livo 1 7,094 15:th-Jun-2021, 19:29:36
Last Post: livo
  Side turning/indicator wiring diagram to help install sequential LED DRL strip. Leady78 0 8,923 11:th-Mar-2021, 17:53:55
Last Post: Leady78
  CD400 power problem bigles 6 8,107 22:nd-Dec-2020, 05:56:33
Last Post: bigles
  Insignia CD400 DAB Issues Dud2020 2 4,131 9:th-Dec-2020, 04:40:11
Last Post: Dud2020
  CD400 upgrade. Hemihunter 2 4,584 11:th-Nov-2019, 09:56:57
  Wiring up my dashcam. Take power from...? rlievens 14 20,324 29:th-Jun-2019, 20:42:29
  cd400 vs navi600 niteram 7 10,804 27:th-Aug-2018, 09:02:10
  navi 600 memory card usb aux wiring tzr608 1 12,538 15:th-Aug-2018, 20:22:32
phbamo (21:st-Sep-2025, 00:06:08), Rustic302 (23:rd-Aug-2025, 11:52:16)
