to problem asap help 900 upgrade needed 600 navi
Navi 600 to 900 upgrade problem! Help needed ASAP!
Hey guys! Trying to update from navi 600 to navi 900 managed to install the stuff from the memory stick but I can't do the stuff from the disc. I burned the disc with windows 7 manual burning. That is the disc
And the file which I need to upload on the disc is that one, right?[Image: 5f01684907e9e439cff2585c0641bea3.jpg][Image: 7ccf55549a75b75b575c2b3ae53e8015.jpg]
If I remember rightly, ages ago since I did this, but you need a CD-R. It will not be able to read an RW (Re-Writeable) disc.
It read it, I manged to update it! Just burned the file on x1 speed
Got stu k on boot loader s ran. It says it executing the files then the screen goes blank. Any ideas please?
I have the same issue with the system going blank at executing bat files. Did you manage to get it sorted out? If so how?
I'm having the same problem
  HOW TO UPGRADE TO A NEW CLUSTER BIGGER DISPLAY AND BETTER LIGTH Skemess 20 33,066 31:st-Mar-2023, 11:29:57
Last Post: Jjmorris90
  how to upgrade the NAV600 to a NAV900. tucpal 317 359,266 9:th-Sep-2021, 16:24:59
Last Post: gparini13
  Map updates for navi 600 zebb.guy@hotmail.co.uk 1 5,415 28:th-Jan-2021, 23:15:27
  Sun Visor Replacement - Help Needed Clueless@Cars 9 19,317 24:th-Aug-2018, 11:07:56
  From Navi 600 to Navi 650 arazek 3 11,447 24:th-Jan-2018, 17:00:28
  Upgrade to alloy door pins tucpal 7 23,011 5:th-Sep-2017, 12:24:44
Last Post: Padster
